20 Most Recent
Omega 6147 Sewing Machine Questions & Answers
Omega 386 xom is breaking
How to thread omega386XOM
which spool pin is it please.
the one on my left or the one on my right ?
also what power cord is correct for this model?
Sewing machine slows to a stop.
When was the last time you oiled it?
Sewing machines need regular oiling as you use them - it sounds like you have or are close to seizing the bearings.
In future, when you smell burning and a machine that should operate at full speed slows down - stop, don't persist in using it.
It clearly has something wrong with it.
Your users manual should cover oiling the machine - there are predetermined points at which you drop the sewing machine or 3-in-1 oil into. Only a few drops are necessary, but you should oil it every few hours of use.
The pattern selector wont turn
If you can get into the top of the machine yopu need to check to make sure the pattern cam is not split and the finger jammed
