20 Most Recent
Casio FX350MS Scientific Calculator Questions & Answers
How can i write this in my calculator example.
What you want to do is solve the linear equation 2x=10 to find the value of the unknown x that makes the equality true. Solving an equation usually involves rearranging therms, factors and so on. However your calculator was not designed to handle the solution of equations, no matter how simple they are.Some Casio scientific calculators can solve some types of equations (polynomials of degree 2 or 3, simultaneous linear equations in up to 3 unknowns). These are the FX-115 ES (Plus) and FX-991 ES (Plus C). Other equivalent models are sold in the world under different names.
Cos theta 50
To calculate the Cosine of an angle, you first make sure that the angle unit on your calculator is set to the correct one (degree, or radian). After that it is all simple. Enter the angle value (50 degrees) then press the [COS] key. If you get an error then press the COS key followed by the angle value then press =.Note if your calculator display Cos ( , with a left parenthesis, then you have to press COS first followed by the angle value and possibly the right parenthesis.Note. The theta here is of no relevance.
How to complex numbers
The fx-350MS does not have complex capabilities. You can do complex calculations the old-fashioned way, breaking each complex number into its real and imaginary components.
I want to know how
Press the MODE key a certain number of times until you reach the screen that says DEG RAD, GRA. Press the number that corresponds to DEG.
I have Casio fx-350 MS.
Cheer up, the calculator can display UP to 10 digits, no more. Internal memory keeps 12 digits. So clearly, this calculator is not fit to handle the precision you apparently are seeking. It may be time to look for a more capable calculator.
How to type log base 2
You can't. However, you can calculate the log base 2 of any number by calculating
log2(x) = log(x)/log(2) = ln(x)/ln(2)
That is, the log base 2 of any number is the log of that number divided by the log of 2.
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
