20 Most Recent
Casio FX82ES Scientific Calculator Questions & Answers
How can i factory reset
Press the [S<=>D] key to convert from fraction to decimal and back. Any information you need is in the manual.
I want 100000 to appear as100,000
I am afraid there is a misunderstanding. The sequence you describe changes the decimal marker from a dot to a comma. It does not insert a thousands separator.
Y>x^2-4x+3
You need to draw the
curve y= x^2-4x+ 3. It is a parabola.
The equality (=) is verified by all points on the curve. The curve divides the whole plane in two regions. In one region
y will be less than x^2-4x+3. In the other regions
y will be larger than x^2-4x+3
The regions are the interior of the parabola and its exterior. To find out the region where your inequality is verified you proceed as follow.
- Look at the graph and choose the coordinates of one point. Select integer values (BTW the point (0,0) is usually a good candidate) and write y ? x^2-4x+3 where the ? stands for the inequality sign you will have to insert to make the relation correct.
- Take x=0, and y=0 and substitute in y ? x^2-4x+3
- 0 ? (0^2)-4*(0)+3.
- Clearly the ? stands for < because 0 <3.
- So at all the points in the region where (0,0) is located the condition y< x^2-4x+3 is TRUE.
In the other region
y < x^2-4x+3, is FALSE and that second region (the one that does not contain the origin (0,0) is the one you need to find.
It represents your solution set. Note that the origin (0,0) does not lie in the solution set region
Open screws
If you want to open it, just undo the screws on the back, there is no secret incantation that one can say to make thing easier than that.
Open it at your own risk.
Area of traingle with tree
All triangles have three sides.
There are two main formulas that do not call on trigonometric ratios.
The classic one:
- 1. You need the length of a base and it corresponding height (the length of the segment perpendicular to that base and passing through the vertex (summit) opposite to that base. Area=(1/2) * (measure of the base)*(measure of the height). The base and height must be expressed in the same unit.
Heron's Formula if you have the length of the three sides. Let those measures be
a, b, and
c.
- Calculate the semi-perimeter p with p=(1/2)(a+b+c)
- Area=Square root of (p*(p-a)*(p-b)*(p-c))
- a, b, and c must be expressed in the same unit.
My calculator is clear all
Press [SHIFT][9] (CLR). Then select 3:All.
Everything will be reset to default.
To setup press [SHIFT][MODE](Setup) and change the
settings you want.
1: to use MathIO display mode; 2: to use the LineIO, 3: 4: 5: to change the angle unit. 6:Fix to set Fixed number of decimals, 7:SCI scientific notation display, 8: Norm for Normal display mode. (read your manual for that).
By pressing the Arrow Down button you get other setup choices.
1: to display mixed numbers, 2: for improper fractions, 3: Stat; 4: to chose the dot or the comma as a decimal marker. 5: to adjust contrast of the screen.
How to solve r in linear regretion
Find the formula for the correlation coefficient and use the calculator to calculate it.
You can also use the calculator to do statistics. It has some keys to retrieve the statistical values calculated. You will find r among them.
Please do read your manual to learn how to do statistics.
Prime factorization
Do you have a question?
Find the prime factors of a natural number.
This calculator does not have a utility/feature that does that for you. However you can use it to help you carry out the sequence of divisions you have to do, while you keep count on how many times you divided by 2, by 3, by 5,7, etc.
Remainder fractions
Hello.You would be looking for a function called 'MOD' which returns a remainder. so 7 MOD 6 = "1".If your calculator does not have the MOD function... then you can do it by 7 divide by 6 = 1.16666... then take the fractional portion 0.16666 and multiple by your divisor, 0.166666 x 6 = "1". So you can easily calculate it.Hope this helpsJeff
