20 Most Recent Timex Ironman 53151 Wrist Watch Questions & Answers
Timex ironman 53151 how to get rid of the hour glass chime
Can’t get rid of the hour glass with some type of half circle with an arrow at the top on the left side of hour glass. This is the Ironman 30 lap. Back plate # 170
5/20/2021 10:29:00 PM • Timex Ironman... • Answered on May 20, 2021
I have a Timex Ironman
got a new battery in ironman and the beep will not sound when i press the start and end button on while in stopwatch mode
2/8/2018 5:14:18 PM • Timex Ironman... • Answered on Feb 08, 2018
Old model timex compact disc digital audio
Hi catlady05,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
1/23/2014 4:33:01 AM • Timex Ironman... • Answered on Jan 23, 2014
Watch isn't recognised by computer
Hi Hoffman518,
To set the alarm on your Timex Ironman, please follow the steps below.
Hope it helps.
8/15/2011 12:45:40 PM • Timex Ironman... • Answered on Aug 15, 2011
How do you set a timex ironman wathc and how do
Hi hdirkse,
Setting an Alarm
Hope it helps.
8/15/2011 12:39:50 PM • Timex Ironman... • Answered on Aug 15, 2011
Have Timex Ironman T51081, no instructions, don't
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
7/23/2011 5:07:32 PM • Timex Ironman... • Answered on Jul 23, 2011
2answers
Set hourly chime
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
7/7/2010 3:26:26 AM • Timex Ironman... • Answered on Jul 07, 2010
The alarm doesn't ring on my ironman triathalon
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get wow gold sale with the lowest price wihit in
10 minutes' fast delivery and you also can enjoy first class service
for your login.
1/23/2010 4:23:35 PM • Timex Ironman... • Answered on Jan 23, 2010
Repair or buy new
WELL YOU SHOULD START WITH A NEW BATTERY ALWAYS A WORTHWHILE CHECK AS THIS COULD BE THE PROBLEM.. ASK ? PLEASE REPLACE THE BATTERY IF MORE THAN THIS QUOTE FIRST
8/3/2007 3:15:36 AM • Timex Ironman... • Answered on Aug 03, 2007
2017 Timex Ironman GPS watch. Where can I buy a replacement battery for it?
It's not that old, did you ask them direct? Servicing is their responsibility normally for at least 10 years. I can't find a battery with three wires either. The Garmin watches have a circular wired battery but only 2 wires.
Watch Repair Instructions & Guide
Timex https://www.timex.ca > watch-repair-instructions Need help with watch repair for your Timex watch? Be sure to read through Timex's watch repair instructions and guide. ... Ironman GPS App.
5/26/2023 1:29:49 AM • Timex Ironman... • Answered on May 26, 2023
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
11/23/2015 6:15:52 AM • Timex Ironman... • Answered on Nov 23, 2015
Timex Ironman 53151 Wrist Watch Logo
22 questions posted
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Ironman Timex
  • Ironman Timex
Most Popular Question
set timex ironman wathc
  • Watches
