20 Most Recent Samsung Galaxy S 4 GT-i9500 Smartphone Black Mist 16GB Questions & Answers
Samsung Galaxy S4: How to open back battery cover:
1) Flip the phone over so you see the back cover..
open-back-s4-samsung-galaxay-cell-phone-kyzl0pi20tqzz121bvlihxv0-2-5.jpg 2) Locate the notch on the side of the phone with your fingernail and pull the cover easily up to unlatch that area and all areas around the phone.. With one hard pull you can easily take off the whole cover.. don't be shy, your Samsung phone is sturdy enough to handle it.
All the blue arrows in the below image shows where the cover clicks into the inside of the phone to keep it closed.
open-back-s4-samsung-galaxay-cell-phone-kyzl0pi20tqzz121bvlihxv0-2-9.png 3.) when you need to put the cover back on the phone.. place the cover over the back part of the phone, noting that the camera hole in the cover goes at the top..
Then grip your left hand on the left side of the phone and your right hand on the right side of the phone.. apply pressure to each side to click the latches to the phone locking it in place.
Afterwards, run your fingers along the back sides of the phone to see if there are any bulges (a latch may not have clicked in place). Either apply pressure there to click it into place or you may have to take the cover off again and try again.
It's very simple and easy once you get the hang of it.
How to Open Samsung Galaxy S4 Back Cover Insert Battery SIM Replace Back...
Bending the back cover will not damage it because it is plastic.. unless you bend it to crease it. Below is Samsung's durability test.
https://www.youtube.com/watch?v=UrhCz6PnT78
(you may need to copy and paste this link to make it work)
Samsung Galaxy S... | Answered on Oct 27, 2019
Try this secret code: Dial *#0228# and press Quick start button. This one calibrate your battery and the next step is full charge!
Samsung Galaxy S... | Answered on Feb 05, 2018
Hi
Samsung phones and probably most other phones store all networks detected throughout their lives unless you select them and tell them to "Forget" particular connections. This applies even when the network settings don't match the settings of the network you are trying to connect to.
I would suggest that you "Forget" the connection you are trying to connect to. After a while the phone will detect the network and if you tap this network it will ask you for a password. Enter this and it should connect it the network without trouble.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Samsung Galaxy S... | Answered on Jan 04, 2015
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Samsung Galaxy S... | Answered on Aug 11, 2014
It is more then likely controlled by your phone provider thus is a question that their support line should be able to answer
Samsung Galaxy S... | Answered on Jun 24, 2014
If your phone was stolen, your best bet is to go to your wireless carrier and let them know, they will block the imei so that it can't be use anymore. The S4 comes with Android Device Manager, which you can control your S4 from a computer, but this will only work if you activated the phone with your google account, try going to accounts.google.com and log in with your google account. Best of luck.
Samsung Galaxy S... | Answered on Mar 13, 2014
Samsung support
https://www.samsung.com/uk/support/model/EC-WB35FZBPBGB/
Do you mean that you cannot send photo from the camera via email on WiFi ?
Have you recently changed your WiFi network password on the router? or reset it?
Samsung Cell... | Answered 26 minutes ago
no its your choice the android system is flexible when it comes to choice
Samsung Cell... | Answered 13 hours ago
Hi are you in need to unlock your Samsung E900 mobile from network lock then visit theunlockarena.com here they ask you the network provider name to which your mobile is locked and the imei number of your mobile .Finally they send you codes to unlock it.
Samsung Cell... | Answered 19 hours ago
Get the unlock code for your samsung A187 model mobile here Superunlockcodes.com and for samsung a197 model mobile from this site Superunlockcodes.com , it gives the best instructions for getting the code for your mobile from the network lock.........
samsung GT-c3200 messages are initializing and loading. what is the solution
Samsung Cell... | Answered on Nov 14, 2019
i am after an unlock code for Samsung SGH-A707
This tutorial is for a Samsung Galaxy S5 phone, it gives you an idea of how to access your gallery if you have any other Samsung Android phone
http://www.samsung.com/uk/support/skp/faq/1053541
Samsung Cell... | Answered on Nov 13, 2019
Samsung Galaxy S 4 GT-i9500 Smartphone Black Mist 16GB Logo
13 questions posted
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
356833053996017
  • Cell Phones
