20 Most Recent Golf Cart Parts & Accessories Energy Displacement Resistor For Club Car Electric 1998-02 48-Volt Questions & Answers
Club Cart what is the little yellow sauare on the dash
Mostly a low battery warning light.
6/17/2020 5:25:39 PM • Golf Cart Parts... • Answered on Jun 17, 2020
Ingersoll rand manuals
3/12/2019 11:50:25 PM • Golf Cart Parts... • Answered on Mar 12, 2019
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
1/31/2016 5:34:12 PM • Golf Cart Parts... • Answered on Jan 31, 2016
Club car won't run its got new batteries 8volt2014 golf car
1/4/2024 2:36:02 PM • Golf • Answered on Jan 04, 2024
Bag Boy Navigator Elite Electric Golf Push Cart. Bought 20 year old Bag Boy Navigator Elite. Needs battery.
Question edited for clarity. Question moved from Computers and Internet. Magic word is 'Golf' Yes according to this it takes a 24 volt Lithium battery. Fortunately putting a 12 volt battery in won't have damaged it where as 24 volts into a 12 volt system will. Take it to your local golf retailer and they will know someone that can diagnose and repair the electronics. I presume you checked the battery had a full charge. The reviews on it are good https://www.google.com/search?q=Bag+Boy+Navigator+Elite ..
12/6/2023 12:16:08 AM • Golf • Answered on Dec 06, 2023
My Golf Logix App isn't working on my iPhone 14 Pro Max.
Question edited for clarity. Question moved from Cars and Trucks category. It may have been corrupted update. Remove the App, reboot the phone and redownload the App. If that doesn't work, contact Golf Logix direct.
GolfLogix Home - GolfLogix - Putt Break Maps and GPS ...
GolfLogix https://www.golflogix.com The Complete Game Improvement App. From tee to green, GolfLogix provides the information you need to reduce strokes and play smarter.
The #1 Golf App
GolfLogix is the #1 Golf App for iOS and Android. Featuring Putt ...
Does GolfLogix Have a Free ...
GolfLogix is the #1 most downloaded app for golf ...
Contact Us
Corporate Headquarters: GolfLogix, Inc. 4235 N ...
Mapped Courses
Mapped CoursesGolfLogix, Inc. ... Los Altos Golf & Country ..
8/15/2023 3:01:47 AM • Golf • Answered on Aug 15, 2023
1996 EZGO STREET READY ELECTRIC GOLF CART. Why does my 96 Ezgo hesitate?
Question edited for a lot more clarity. Question moved to Golf Carts. Probably a dirty throttle controller. Strip down and spray with electrical switch cleaner. https://www.google.com/search?q=1996+ezgo+electric+hesitates ..
8/5/2023 6:32:44 PM • Golf • Answered on Aug 05, 2023
Navigator Elite Golf Cart saying top box not connected what causes this and how to fix it?
Question edited for clarity, as this appears to be golf related? All questions need 'make model (what it is)' please. Question moved from Cars and Trucks. Ask the maker or a dealer. https://www.google.com/search?q=Navigator+elite You are the only person to have this issue. https://www.google.com/search?q=Navigator+elite%2C+top+box+not+connected ..
6/25/2023 12:16:57 AM • Golf • Answered on Jun 25, 2023
2answers
Caddylite 11.5V2 brake assembly
not car is it. it is golf caddy , i yes be more clear moved you from automobile cars to golf the answer is ask the maker for help
6/4/2023 4:03:28 PM • Golf • Answered on Jun 04, 2023
Powercaddy Fx3 battery unable to remove
find and buy the manual,lost it,sure. ask the maker of the caddy for the manual they have it. so ask? the end of battery has lever,looks like a hinge. so move the lever and it comes right out. https://youtu.be/NIQyxKcoV5Q?t=476
5/31/2023 8:24:51 PM • Golf • Answered on May 31, 2023
2answers
I have a Patterson Eventer golf buggy, it goes about 12 inches and stops abruptly in forward or reverse. What's wrong?
Question edited for clarity. Question moved to golf. Solenoid. (electro-magnetically operated switch) What are the symptoms of a bad solenoid in a golf cart? On an electric golf cart, the most common symptom is the solenoid is not delivering electricity to the controller when the vehicle's ignition is turned on. In normal operating conditions, the solenoid clicks on and off with the ignition switch. A failing solenoid will generally not click. https://www.google.com/search?q=patterson+golf+buggy+solenoid If it clicks, it is more likely to be the accelerator potentiometer, basically the variable gas pedal. Great resource in the link for Golf Cart woes. https://www.golfcartsforsale.com/blog/5-common-electric-golf-cart-problems-solve/ ..
5/12/2023 8:43:11 PM • Golf • Answered on May 12, 2023
What model and year is a Western Golf cart with model number 10008411886. I located this number on the frame, under the passenger seat.
That is actually the Serial Number. Looks to be 1984 11th month, November. 84-11 - 1886 number made https://www.google.com/search?q=western+golf+cart+serial+number+lookup ..
5/11/2023 9:40:32 PM • Golf • Answered on May 11, 2023
2009 G29 Yamaha Golf Cart. Kids didn't plug in charger correctly and melted the charging port and plug. Changed both still won't charge. Charger does not work either.
If the charging port and plug have been replaced and the charger still does not work, there may be an issue with the charging circuit in the golf cart. Here are a few things you can check:
  1. Charging fuse: Check the charging fuse to see if it's blown. If it is, replace it with a new one of the same amperage.
  2. Charging relay: Check the charging relay to see if it's working properly. You can do this by using a multimeter to check the resistance across the relay contacts. If there is no resistance, the relay is bad and needs to be replaced.
  3. Charging receptacle: Check the charging receptacle to make sure it's getting power. Use a voltmeter to check for voltage at the charging port.
  4. Charging controller: The charging controller may be damaged if the charging port and plug were melted. Check the charging controller for signs of damage or overheating. If it's damaged, it will need to be replaced.
If none of these solutions work, it may be best to take the golf cart to a professional mechanic or dealer for further diagnosis and repair.
2/28/2023 4:58:11 AM • Golf • Answered on Feb 28, 2023
2answers
Where can i get s cotter pin replacements for my touttrek hard golf case
any hardware store
2/17/2023 5:44:08 PM • Golf • Answered on Feb 17, 2023
How to connect 4 12 volt batteries to Yamaha golf cart please
It depends on the model, but they are usually wires in series to give 48 volts to the motors, so plus to minus on each them. Cart positive lead to batt 1 + the - to batt 2 + to batt 3 - to Batt 4 + and the minus - of batt 4 to the cart. Videos https://www.google.com/search?q=how+to+connect+4+12+volt+batteries+to+Yamaha+golf+cart You could also search make model manual ..
1/28/2023 12:15:09 AM • Golf • Answered on Jan 28, 2023
2answers
Ezgo electric golf cart wiring diagram
1/27/2023 5:05:19 AM • Golf • Answered on Jan 27, 2023
EZGO golf cart will not go
It's possible that the motor, solenoid, or wiring has become disconnected or damaged. I recommend starting with a basic inspection of all the connections, wires, and components. If all looks alright, then you may need to have the motor and solenoid tested. If there is still no luck, then you may need to replace the EZGO golf cart motor or solenoid.
1/15/2023 6:40:50 PM • Golf • Answered on Jan 15, 2023
Coco Electric Truck Manual
11/20/2022 10:58:47 PM • Golf • Answered on Nov 20, 2022
Golf Cart Parts & Accessories Energy Displacement Resistor For Club Car Electric 1998-02 48-Volt Logo
4 questions posted
Top Golf Cart Parts & Accessories Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Cart Parts & Accessories Golf Expert? Answer questions, earn points and help others
View Most Popular
  • Golf Cart Parts & Accessories Golf
Most Popular Question
ingersoll rand manuals
  • Golf
