20 Most Recent Onkyo HT-S580 System Questions & Answers
open and blow clean the insides and try. had worked for me.
Onkyo HT-S580... | Answered on Dec 29, 2017
You need press the input button on your TV's remote.Then you need to select the input setting for HDMI.On mine,there is also an HDMI 2 input so depending on how your's is wired,it could be either one but that should get you what you want to achieve.Good luck,Greg
Onkyo HT-S580... | Answered on May 06, 2011
you might want to switch the speakers that youre using. e.g front left put it to front right and vice versa to isolate if the speaker has the issue or the amplifier terminal.
if the left speaker works on the other terminal then its a terminal issue.
Onkyo HT-S580... | Answered on Mar 03, 2009
Most systems like this have what is commonly called 'protect' mode. This usually kicks in when the volume is at a very high level, and the unit tries to use more power than its designed for, or it is overheating. The reason why only this connection has problems and others do not could be a few reasons. One, satellite signals usually carry high quality digital sound, and use more power to play sounds that may be inaudible. Two, You may also want to upgrade your composite cables to the highest possible quality. (There are many durable gold plated models that work well). Low quality cables could hasten your problem and produce signal bleed. In addition to this, the unit may cut power when it overheats. Make sure the vents on the unit are not obstructed, and that it is not near other components that are generating heat.
Onkyo HT-S580... | Answered on Nov 13, 2007
You should adjustb it to what sounds good to you, as industry standards with a sound pressure meter says to start out at 0 db level. You should read this link and others at this other site. http://www.techlore.com/article/10037/
Onkyo HT-S580... | Answered on Sep 23, 2006
Hi Madhu, I am a bit confused with your questions. If this has not been resolved for you please give us a call at 800-229-1687 as our Product Support Team is ready to assist 24/7, Thanks, JT
Onkyo Audio... | Answered on Jan 12, 2020
Your replacement remote (control) is not functionally equivalent to the other.
Onkyo Audio... | Answered on Jan 09, 2020
Check the equilibrium of speaker
Onkyo Audio... | Answered on Jan 04, 2020
See page 15 of the Manual (power transformer T901):
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Onkyo-DXC-380-Service-Manual.pdf
For British model see page 3 of the Manual (AC plug is fitted with a 5 amp fuse):
https://www.intl.onkyo.com/downloads/manuals/pdf/dx-c380_manual_e.pdf
Onkyo Audio... | Answered on Dec 16, 2019
Onkyo HT-S580 System Logo
Popular Tags
12 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
onkyo ht s580 will not turn shuts off
  • Audio Players & Recorders
