20 Most Recent
HHB BurnIt CDR830 CD Recorder Questions & Answers
Hi there, when recording analogue
I can only assume that it's not changing the analogue signal into a format suitable for transferring to a CD. Check the recording settings. Make certain the signal is being converted to say a WAV format or MP3 etc.
Need remote for my hhb butnit plus
Either contact hhb or look on E bay. Universal remotes usually do not have enough of the functions required to finalize discs and such.
How do i record from my decks
You have to have the proper dics, One that is for recording music, Not the ones for burning music off of the computer, They will not work, In a (CD) Recorder/
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
Hi ,
My cdr 830 stopped recording at maximum
I can't speak to the hardware issues that might be at play here but I would advise you to retain the 'bad' recordings. I've copied unfinalized CD's from an old DVD player. It will read the CD but you won't be able to manuever around the tracks. As I recall, the track marks will still be there.
I don't know what you mean by 'maximum fidelity'. The CDR records at the CD standard of 44.1kHz. Digital is all ones and nones. Just data. If it is written correctly or with tolerable errors the ADC of the player (ANY player) turns it all into music.
