20 Most Recent Nordic Track NordicTrack T5 zi Treadmill Questions & Answers
Our NordicTrack T5 zi treadmill belt is not moving...
Belt Not Moving: If the belt isn't moving, there are a few potential causes. One common issue is a faulty motor controller. Even if the red LED on the control panel is lit up, it might not be sending voltage to the motor. To check the motor, follow these steps: First, test the motor using the methods outlined in this guide: Motor Testing. Motor Testing (treadmilldoctor.com) If the motor is working, the motor control board may be the culprit. Console Wire Check: Inspect the console wires that run from the motor board through the primary wire. Loose or damaged wires can cause the belt to stop moving. Reconnect any loose wires. Smoking Smell: The smoking smell you noticed could indicate an electrical issue. It's essential to address this promptly. Off-Center Belt Alignment: If the belt is off-center, it can cause problems. Confirm that the treadmill is on level ground by using a bubble level. Then, follow these steps for belt alignment: Belt Moves to One Side. How to Fix Treadmill Belt Slipping to One Side ' Stay Centered (treadmilldoctor.com) Loud Mechanical Sound: The noise during operation might be due to misalignment or worn components. Inspect the treadmill's moving parts for any signs of wear. Retirement Decision: Based on the severity of the issues and potential repair costs, you'll need to decide whether it's worth fixing or if it's time to retire the treadmill. Professional Inspection: If you're unsure, consider having a professional technician assess the treadmill.
3/31/2024 6:45:09 PM • Nordic Track... • Answered on Mar 31, 2024
Show motor brush cover on nordic
THE PLASTIC COVER WHERE THE SMALL BRUSH OF THE TREADMIL NORDICTRACK L-355197 MOTOR GOES BROKE. WHERE CAN I GET THIS COVER?
1/22/2022 7:52:57 PM • Nordic Track... • Answered on Jan 22, 2022
My Nordic track T5 zi only beeps 3 or 4 times no
Take another look at the answer above by spamslisher. This was exactly the problem I had. The control panel gave four quick beeps every ten seconds and the treadmill would not start or respond at all. The problem was a stuck button on the control head. That diagnosis was thanks to the tip from spamslisher above. I tried all the keys until I found one that didn't beep. That was the stuck key. In my case it turned out to be the down arrow on the ifit row, same as for spamslisher. After opening up my control panel it was easy to see how to disconnect the ifit control board from the main board. I did that and my problem was solved. Like spamslisher, we never use the ifit feature anyway so nothing lost there. Thanks for the really helpful tip. I doubt I'd have figured it out without you.
1/4/2020 5:16:19 AM • Nordic Track... • Answered on Jan 04, 2020
My TZ5I console was displaying numbers, but the machine would not respond or work. The speed would vary without touching any buttons. I held the stop button for a few seconds and the consile went blan
There 2 possibilites that you must test: 1) test the voltages coming from Controller motor board to the console, if there are the console is FAULTY!! replace 2) If there are NOT, voltage from controller motor board, this board is fAULTY rEPLACE LED Blink Patterns on the Control Board Treadmill Blessing [email protected] cell+whatsApp: +50588611441
1/25/2018 5:21:08 PM • Nordic Track... • Answered on Jan 25, 2018
0answers
0answers
Nordic Track NordicTrack T5 zi Treadmill Logo
82 questions posted
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
treadmill stuck
  • Exercise & Fitness
