20 Most Recent
Star trac ST Fitness 8921 Treadmill Questions & Answers
Treadmill Star Trac 4500 won't start
Checkout this latest Tops & Tunics
Product Name: *Fancy Graceful Women Tops & Tunics*
Fabric: Rayon
Sleeve Length: Three-Quarter Sleeves
Pattern: Embroidered
Multipack: 1
Sizes:
XL (Bust Size: 42 in, Length Size: 27 in)
XXL (Bust Size: 44 in, Length Size: 27 in)
Country of Origin: India
Easy Returns Available In Case Of Any Issue
*Proof of Safe Delivery! Click to know on Safety Standards of Delivery Partners- https://ltl.sh/y_nZrAV3
8/22/2021 4:33:13 AM •
Star trac...
Answered
on Aug 22, 2021
Light says no rpm
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This message appears when the rpm sensor becomes damaged or misaligned.Remove the shroud located at the front of the treadmill to gain access to this component.
The rpm sensor is locted between the motor and the flywheel, there should be about 1-2 credit cards gap between the sensor and the flywheel. Large amounts of dust and debris buildup on the flywheel itself can cause the sensor to not pickup a reading, however if the flywheel appears to be clean, the sensor should be replaced.
After replacing the sensor, you will need to run the unit through a calibration procedure.Press and hold the "0", "1", and "Start" at the same time, then release the "1" key.The display will read MAINTENANCE, then press and release the "8" key.After the "8" key has been pressed, On the newer 4000 series press the "Heart" key to perform calibration.Once the "Heart" key is pressed the calibration will perfom. After the process is complete, the NO RPM error should clear itself out.
NO RPM Error and Why it Displays on StarTrac treadmill
11/30/2015 4:20:29 PM •
Star trac...
Answered
on Nov 30, 2015
Olympus Sport exercise bike, model OS-11202. Resistance braking (gear/level change) is not working.
1. CHECK THE RESISTANCE KNOB: MAKE SURE IT'S NOT STUCK OR DAMAGED. TRY TURNING IT TO SEE IF IT ADJUSTS THE RESISTANCE.
2. INSPECT THE RESISTANCE MOTOR: SOMETIMES THE MOTOR THAT CONTROLS THE RESISTANCE MAY BE MALFUNCTIONING. CHECK FOR ANY SIGNS OF DAMAGE OR WEAR.
3. RESET THE BIKE: TURN OFF THE BIKE, UNPLUG IT, WAIT FOR A FEW MINUTES, THEN PLUG IT BACK IN. THIS MAY RESET THE SYSTEM AND FIX THE ISSUE.
4. CONTACT CUSTOMER SUPPORT: IF NONE OF THE ABOVE STEPS WORK, IT'S BEST TO CONTACT OLYMPUS SPORT CUSTOMER SUPPORT FOR FURTHER ASSISTANCE.
