20 Most Recent
Tunturi T40 Treadmill Questions & Answers
I was running on the
Is it under warranty if so take it back if not buy a new one its more efficient and safer
Error 1 is displaying on the screen. It just
E1 stall error is usually a lower board problem, that means you may have to replace the lower board.
Here is a list of things that will cause this to occur:
a. Improper lubrication of belt/deck (too much friction and amperage draw)
b. electrical variance (example: going from US 110 to foreign 220)
c. potentiometer on control board may be set too low (usually blue box
with turnable dial) - to change this you would have to turn the dial
ever so slightly and test after each movement until the belt starts to
run on its own without the error.
Other than the above issues you would have to replace the motor control board and check speed sensor.
Additionally, here the
T40_09_User_Manual.
Hope this helps.
Where does Power Cord plug in on a Tunturi R60 Rowing Machine?
It sounds like you're having trouble finding the location where the power cord for your Tunturi R60 Rowing Machine should be connected. I recommend checking the front frame of the machine thoroughly. It's possible that the plug may be located in a small or obscured location, or it may be covered by a removable panel. If you still can't find the plug, you may want to contact Tunturi customer support for assistance. They may be able to provide more specific guidance on where the plug is located on your particular model.
Tunturi T60 treadmill problems with the PSC
The PSC (Power Supply Control) error message on a Tunturi T60 treadmill typically indicates a problem with the power supply or the control board.
Here are some things you can try to troubleshoot the issue:
- Make sure that the treadmill is properly plugged in and that the outlet is functioning properly.
- Check the fuse or circuit breaker and replace it if necessary.
- Inspect the power cord for any damage or fraying and replace it if necessary.
- Check the control board and wiring for any damage or loose connections and repair or replace them as needed.
If the problem persists, it may be best to consult the user manual or contact Tunturi customer support for further assistance.
If you are unsure about troubleshooting or repairing the treadmill, it's recommended to have a professional fix it to avoid any injury or damage.
How to fix error e1 on tunturi rowing machine starfit r100
Error code E1 on a Tunturi rowing machine typically indicates a problem with the resistance system. To fix this issue, try the following steps:
- Check the resistance settings to ensure they are set correctly.
- Make sure the resistance knob or lever is not loose or damaged.
- Check the flywheel and belt to ensure they are properly aligned and not damaged.
- Make sure the machine is properly lubricated.
- Check the power source and ensure the machine is properly plugged in and turned on.
- Try resetting the machine by unplugging it for a few minutes and then plugging it back in.
If the problem persists after trying these steps, it may be best to contact the manufacturer for further assistance or to schedule a service appointment.
MY TUNTURI J8F NON START AND DYSPALY ERROR 13. CAN YOU HELP ME?
If your Tunturi J8F treadmill is not starting and displaying an error code 13, there may be a problem with the treadmill's control panel or other internal components.
Some potential causes for this problem include:
- The control panel may be faulty. If the control panel is not functioning properly, it may not be able to start the treadmill or display the correct error code.
- The wiring for the control panel or other components may be damaged or disconnected. Check the wiring to ensure it is secure and in good condition.
- The treadmill's motor or other internal components may be faulty. If the motor or other components are not functioning properly, the treadmill may not be able to start or operate correctly.
If you are unsure how to check for and address these potential causes, you may want to consult the user manual for your Tunturi J8F treadmill or contact the manufacturer for assistance.
Motor Drive Belt Tunturi J620P Treadmill
Please check with Mcmaster carr, ebay and amazon to find your treadmill part. You can also check out alibaba if the 3 prior sources don't work out for you.
Thank you.
