20 Most Recent
Sole Fitness F63 Treadmill Questions & Answers
Treadmill will not enter Factory Settings or Engineering mode. Can I reset the software? I spoke with Sole and they cannot help.
Idk how old your treadmill is but sole offers very good warranties on some parts even up to 5 years so maybe you can have them go out and repair it for you BUT from the sound of it they could not help you out so the only thing left is to do simple troubleshooting.
You can try just resetting the power switch, to off. Disconnect the power cord from the outlet and leave the machine be for about three minutes.
Reconnect and switch back on, then just Press and Hold the START, STOP, and ENTER key at the same time, until it displays "engineering mode" (it might say maintenance depending on the version) then just press the ENTER key.
If it works you can scroll through the menu with the SPEED UP and DOWN keys.
If it does not let you still, you might have an issue in your console and it needs replacing but it is not limited to just the console, there could also be an issue with a component on the Main Board (Circuit Board) or other electrical components.
Hope this helps!
Sadly we do not carry any sole products yet, but we would be happy to help you find a technician in your area to come out and help.
You can give us a call at 888-713-2880 or talk with us by chat at
www.sportsmith.net Good luck on the repair :)
Treadmill Elevaton Error
There are a few things you may need to check. You already tried calibration. Next thing I would do is check the sensor wire from the incline to the controller. Make sure its properly plugged into the controller. The controller can also be an issue. If someone was tampering with the unit, the sensor wire could be plugged into the wrong connector as there is another connector that will fit. You may contact me for phone support or sign up for phone support at
Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
The belt on my Sole F63 will not turn
It sounds like you have a blown motor controller. If your machine is older than 5 years then that's pretty normal for sole. Their belts don't last very long and they cause stress on the controller. You'll have to replace the motor controller and the walking belt.
My Sole F63 treadmill belt either fails to start or starts only with some coaxing
You may have a few different issues. it sounds like you may have motor or motor brush issues. If the motor brushes are burnt then they don't make proper contact with the motor so they won't be able to power it unless you help it along with your foot. If you are the original owner of the machine and have a proof of purchase that motor should be covered under warranty. The stop issue is a weird one. It's probably just that the stop button isn't working and that's a pretty inexpensive fix.
I would definitely not use the machine until you've had a technician look at it. I am going to guess that the treadmill is over 6 years old. If it is then on top of everything else you'll need a new walking belt. To put one cent into that machine and not replace the belt is a complete waste of money. The problems will all come back and they'll be much worse.
