20 Most Recent Icon Epic 450 MX Treadmill EPTL09605 ! Questions & Answers
Comes on but will only go to #1 on speed! incline goes up but will not come down, unpluged and reset, however it stays in the same place. I did get the fan to come on! help
1) The main board control can be faulty, by worn deck belt2)motor can be burn3) Adjust the potentiomente in the elevation motor4)lube the gear and shaft from elevation motor5)gearing slips fix it.5a) Run the calibration software for diagnose and troubleshooting6) Tight the connector very well from sensor see the illustration.6_2_2012_9_33_57_am.gif6_2_2012_9_34_45_am.gif
6/2/2012 9:35:51 AM • Icon Epic 450 MX... • Answered on Jun 02, 2012
Picture reed switch and magnet and pulley
12_27_2011_7_09_45_pm.gif12_27_2011_7_09_57_pm.gif12_27_2011_7_10_28_pm.jpgsincerely. Happy New Year. G-d bless you.ernesto cuadramanagua, nicaragua
12/27/2011 7:11:12 PM • Icon Epic 450 MX... • Answered on Dec 27, 2011
My incline stopped working a few weeks ago. Now I
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
8/13/2010 6:19:09 PM • Icon Epic 450 MX... • Answered on Aug 13, 2010
My treadmill got wet the motor runs but the platform belt wont turn
1) Try to get out the controller board motor, and put In bag dry Rice, by 48 hours. 2) clean the board with special contacts cleaner or board electronic( you can buy from any electronic store). 3) Put again the board in the treadmill, If work is ok, IF not the components like IGBT is fault, Replace the completely board. Blessing [email protected] cell+whatsAPP:+50588611441
11/3/2017 1:31:40 PM • Icon Exercise &... • Answered on Nov 03, 2017
2answers
I need a schematic for a mc-70 pwm motor
These are a closely guarded secret and not available outside of the factory.
What do you need it for?
6/29/2017 5:33:57 PM • Icon Exercise &... • Answered on Jun 29, 2017
Where do I find the fitbit connect icon ?
To force a sync on your computer, right click the Fitbit Connect icon (fitbit icon located next to the time) and then click "Sync Now".
10/26/2016 5:34:36 PM • Icon Exercise &... • Answered on Oct 26, 2016
2answers
My Proform 8.5 personal fitness trainer will no longer work
Hello there, It seems that you have a stuck button or a problem with the ifit card area. Yes I know you probably dont use it but just listen. If you have the demo card for the unit try putting the demo card into the ifit slot and press it in and out a couple of times. This will sometimes correct this problem. If that does not correct it then you will need to replace the console or possibly disconnect the ifit section from the console itself. Either way you will need to remove the console.
If more info is needed please leave me a note here and I will get back to you asap.
Good Luck! Tim
8/31/2016 9:14:32 PM • Icon Exercise &... • Answered on Aug 31, 2016
What does the telephone icon on my fitbit charge mean?
It's likely your call display
5/14/2015 10:08:26 PM • Icon Exercise &... • Answered on May 14, 2015
Icon Epic 450 MX Treadmill EPTL09605 ! Logo
Popular Tags
5 questions posted
Top Icon Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Icon Exercise & Fitness
Most Popular Question
comes but will only go 1 speed incline
  • Exercise & Fitness
