20 Most Recent
Dewalt 13 in Planer Questions & Answers
My dewalt dw735 planer just stopped working. There
LOOK TO YOUR connections on the electric field as second thing to do. both statorcoils must have the same level on ohms .
BUT it can be remarkable that you then if its not to find in there thats only a broken wire - cable problem or something with or inside the switch. or just an sliding contact.
The drive belt on a
The pully which quides the belt must be perfectly level in both the horizontal and vertical positions. Use a metal square to check alignement and adjust using adjustment screws.
I have a Dewalt 735
The white wire is the Neutral return wire and goes on the right hand side of the plug viewed from the pin side with the round earth at the bottom. The black is the live wire and is the other pin next to the neutral one, and the big round one at the bottom is the earth wire and is green.
I have a dewalt dw077 self leveling laser. It will not turn on! Battery is good!
Well, I opened a DW077 today as it didn't wanted to turn on. It was brought to me by a neighbor and he hadn't a clue what made it stop working. I removed the outside screws and rubber feet using a Torx T10 with a hole in the middle. Be careful not to remove the screws arranged in a square pattern as these hold the steppers in place. You don't want to mess with calibration ! Also be gentle with the rubber around the rotating head. You need to remove the metal ring on the outside to detach the rubber grommet.. Once open, there is not much to be found inside. There is one pcb, two steppers and some other plastic stuff. Measuring over the big cap indicated 0.9v and over the small cap I had a unstable low voltage. After desoldering some wires, the underside of the PCB can be inspected (all components are on the underside). What I found there was that the main capacitor (1000µF 50v 105°C) of the 5v voltage regulator circuit was blown and leaking electrolyte. Not only was the capacitor gone, it also took an SI4532A mosfet array with it. The 3A fast chip fuse was still intact. The circuit pulled +- 10mA at rest and it went up to 20ma when depressing the power button. That SI4532A chip consists of a P and N mosfet in an SOIC 8pin package. The N side had a hole and the pins were blackened. My guess is that this controls the power on-power off signal that goes to the LM2596-5 buck regulator. I have made some pictures of the damage. So this is a route to research. Hope it helps someone
How do i change spring contacts on dewalt 087 laser
Are there spareparts in US for this DW087 ?
In Europe there are spareparts for to get !
Its for Milwaukee in Europe that there are little Milwaukee tools where nothing is to get but in australia all parts and may be in the states to.
All based on marketing technical decisions and differences.
