20 Most Recent
Poulan Pro Lawn Tractor 2006 and Newer Ground Drive Mower Belt Questions & Answers
What is the actual drive belt size in inches for 300ex
IT is likely that the proper part number is listed on a tag under the hood. If not you can get the units model and serial number off of a tag under the seat and your local AYP dealer can get you the proper belt. I suggest getting the proper belt. First, there is not much cost difference. Second the ' v' on the OEM belt is different from an automotive belt and will last longer. Lastly, AYP lengths are usually a bit off like 1/2 x 95 5/8 so the even numbered automotive belts wont be the correct length.
Overheating
remove the top cover on from the engine and see if there is a nest built up under the cover
Hi trying to put a
on most mowers the drive belt is on top and the blade belt is the lower one.
don't forget to vote for me.
thanks
