20 Most Recent
Blaupunkt Montreal CD34 CD Player Questions & Answers
Sony Model # CDP-H1750 -
Sounds like the mechanism has worn out on the Sony Model # CDP-H1750 5 CD unit.
If it's an aftermarket radio/CD Player, I would replace it if it is out of warranty.
It's unclear from the description whether it is a Sony or a Blaupunkt Montreal CD34 CD Player or whether they are the same unit.
At any rate, such radios are considered to be not very cost effective to repair when out of warranty.
1/19/2011 5:17:58 PM •
Blaupunkt...
Answered
on Jan 19, 2011
Blaupunkt montreal cd 34 Sound Shutoff
I don't think it has a low wattage setting. Have you tried hooking up another deck to see if the problem carries over to the second head unit. Most usually when a head unit shuts off like that, you first worry is true. Are you using the factory wiring in the vehicle?? May I also suggest pulling the head unit out and hooking up all four channels using after market wiring. By using this troubleshooting method is would give you a definate answer on your wiring problem. If The problem persist, then it could be the head unit itself is going bad. Also, one last thing, even if you think the speakers are fine, if one of the speakers is malfunctioning, then it would also cause the player to kick into safe mode.
8/23/2009 5:52:16 AM •
Blaupunkt...
Answered
on Aug 23, 2009
Stereo removal
they have to be introduced and pushed on both sides , maybe you hear a "click", maybe not, and you may help with a hand if you get the back of the headunit(hu) pushing to you.maybe i can help more if you sendme a closer picture. sometimes you have to take off the plastic molder that are over the edge of the hu
9/17/2007 3:59:03 PM •
Blaupunkt...
Answered
on Sep 17, 2007
Hi thereI have a holden barina 2004 with a Blaupunkt 2020 radio.
Radio codes are unique to each vehicle and are typically provided by the vehicle manufacturer or the radio manufacturer. To obtain the code for your specific radio, you will need to contact a Holden dealership or a Blaupunkt authorized service center. They will be able to assist you in retrieving the correct radio code.
You may need to provide proof of ownership and the serial number of the radio (which you've already provided as BP248554092649 No 92 094 577). Once you have the correct code, follow the instructions in your owner's manual to enter it and unlock your radio.
Suzuki Ignis radio code
Hi I have suzuki ignis too and I have problem with radio code too...but I am from slovakia and my english is so amynous...and I dont understant this web side (
www.ukbookshelf.co.uk) its free ?
39101-86G1
ID: 39101-86G1.......like gedwards80 on the top :)
