20 Most Recent
Sony Cyber-shot DSC-TX30 18 Megapixel Rugged Digital Camera - Black Questions & Answers
SD card won't format
A memory card must be formatted in the camera where it will be used in. So never format a SD card in a computer and then place it in the camera. There are camera's that won't even accept a card formatted in the same brand and model camera. Then don't forget to unlock the DS card and make sure all contacts on the memory card and in the camera are clean and shiny.
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
How can I change the language on my Sony DCR PC-100? I'm trying to change it from Japanese to English but I cant seem to find the solution online as well as from reading the manual.
The Sony DCR-PC100 is a camcorder model that was released before touch screen interfaces and language settings became more common on consumer electronics. As such, it's possible that this specific model might not have a built-in option to change the language from Japanese to English, especially if it was originally sold for the Japanese market.
However, there are a few general steps you can try that might help:
- System Menu: Check the camcorder's settings menu for any language-related options. Look for a "System" or "Language" menu where you might be able to change the language settings. Keep in mind that the menu options might still be displayed in Japanese, so you might need to rely on symbols or context.
- Reset to Defaults: Some devices have a "Reset to Defaults" option that might reset all settings, including language, to the factory defaults. This might be worth trying if you're unable to find the language settings.
- Contact Sony Support: If you're unable to find a solution through the manual or online resources, it's best to contact Sony customer support for your region. They might be able to provide specific guidance or let you know if changing the language is even possible on the DCR-PC100.
- Third-Party Resources: Search for user forums or online communities where other users might have faced a similar issue and found a solution. Sometimes, enthusiasts or experts in those communities can provide helpful insights.
- Professional Assistance: If all else fails, consider reaching out to a professional technician or service center that specializes in Sony camcorders. They might have experience with older models and could potentially assist you.
8/5/2023 10:14:51 AM •
Sony Cameras
Answered
on Aug 05, 2023
SONY DSC-S40 RESET IT SELF.
If you have already cleaned the lens gears and the issue persists, it is possible that the lens electric motor is not working properly. You can try resetting the camera to see if it helps. Here are the steps to reset the Sony DSC-S40:
- Turn off the camera and remove the batteries.
- Wait for a few minutes before reinserting the batteries.
- Turn on the camera and see if it works.
If the camera still does not work, it may be a hardware issue and you may need to take it to a professional repair service or contact Sony support for further assistance.
2/26/2023 2:52:49 PM •
Sony Cameras
Answered
on Feb 26, 2023
