20 Most Recent Briggs & Stratton Breaker Point Plunger 298125 298125s Briggs Stratton Questions & Answers
Can I use unleaded fuel in my 1972 3hp engine
Lead is basically a lubricant with additional octane boosting properties for gasoline powered internal combustion engines. Engines intended to run with leaded gasoline that are provided with with unleaded gasoline instead are subject to overheating and failure. Read more about lead here: Why Lead Used to Be Added To Gasoline Your best bet would be to use leaded gasoline - or in the absence of a leaded gasoline source, a lead additive or substitute. Most autoparts stores sell this - and if you're not near one that does - Amazon has it: Amazon com lead additive for gas Good luck!
5/13/2014 10:32:38 PM • Briggs &... • Answered on May 13, 2014
0answers
I have an older Wards
yes, after you pull the flywheel you will see where they are. it may just be the condensor. but while there replace point and condensor.
6/8/2011 11:05:42 PM • Briggs &... • Answered on Jun 08, 2011
Have an older tiller w/a
First check continuity of coil to ensure there are no breaks .If there is a wire heading in under the flywheel, it is probably going to the points. Check coil is grounded properly.
The points are normally behind the flywheel which you will have to remove using a pullers. The nut holding the flywheel on to the shaft normally loosens in the same direction as the flywheel rotates but if there is any shaft thread exposed above the nut, check the threads to confirm this.
The capacitor near the points may be shorted, disconnect it to check this with a continuity tester.
3/11/2011 4:29:37 PM • Briggs &... • Answered on Mar 11, 2011
I have a 14 hourse Briggs$ stratton cast iron
Do you have a starting or running problem? Any spark will ignite gasoline.
Describe you exact problem, and I can help.
Thanks,Matt If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
12/11/2010 1:55:49 AM • Briggs &... • Answered on Dec 11, 2010
My dewalt jackhammer starts for 5 seconds then stops but continues making a humming sound. It starts going again if I let go of the trigger and press it again
Maybe a thermal problem in the electronic modul and also control the powercable on a leight tensile load.
8/18/2022 8:58:28 PM • Hammering • Answered on Aug 18, 2022
Kango 950 does not hammer.motor is working, gears are ok. I have dismantled machine and cannot see anything broken
kango 950 was the hammer drill version. Usually when they stopped hammering they were due for a rebuild. These units have a aluminum piston that rides in a steel tube striker. When the 2 rubber piston rings wear out you will get the described problem. The Kango's use a special tan grease so you cannot just yank it apart and replace the 2 rings with o-rings and grease. I had to rebuild 15 900 and 950's because the previous mechanic used the wrong grease. https://project21designs.com/kango-950-parts The link sells grease & rings.
6/3/2022 2:14:01 AM • Hammering • Answered on Jun 03, 2022
Kango 950 motor runs but hammer only engages sometimes
This is an indication that the hammer needs service. When you take the barrel off you will see the striker. There is a piston inside the striker, when the rubber rings on the piston wear out you have the problem you describe. time to replace the motor brushes clean and regressed, make sure to use the correct grease, Check the backlash on ring and pinions. Don't put too much grease on the piston or it will stick and not strike. Good luck I forgot to ask which version. This is for the uk atlas coco, silver with blue or red handle
5/29/2022 2:06:56 AM • Hammering • Answered on May 29, 2022
How much is a kango 426 hammer drill
kango hammer ' Power Tools ' Gumtree Australia Free Local ...
https://www.gumtree.com.au > ... > Power Tools Find kango hammer ads in our Power Tools category. Buy and sell almost anything on Gumtree classifieds. Missing: 426 ‎' Must include: 426 Ads Kango Concrete Tools - View our Concrete Tools Here Ad·https://www.kangotools.com.au/concrete/tools Kango Concrete Tools get the job done. See our range & find your nearest stockist here. Kango has you covered for all things Concreting. View our wide range of tools here. ‎Concrete Tools · ‎Bricklaying Tools · ‎Carbide Technology · ‎Plastering Tools · ‎Drill Bits Kango hammer: Search Result ' eBay Ad·https://www.ebay.com.au/ Free Shipping Available. Buy Top Products on eBay. Money Back Guarantee! Daily Deals. eBay Plus. Returns Made Easy. Huge Selections & Savings. Fast 'N Free Shipping. Buyer Protection Program. World's Largest Selection. Make Money When You Sell. ‎eBay Tuesdays · ‎Sell on eBay · ‎The Latest Tech · ‎Home & Garden · ‎Everyday Essentials
5/5/2022 3:54:10 AM • Hammering • Answered on May 05, 2022
Cant find turmopol oil
10/15/2021 5:29:59 AM • Hammering • Answered on Oct 15, 2021
I am looking for a manual of the detroit demolition breaker 1700W
Contact the manufacturer/distributor to inquire.
3/15/2021 12:35:44 AM • Hammering • Answered on Mar 15, 2021
Where can I get a set of brushes for a kango 950X
Unfortunately, you won't find them - Kango was a great hammer, but the company has been gone for many years and there are no parts available. I would find a local repair shop that may have a different brand brush that is the same or bigger dimensions - by using a piece of 220 grit sandpaper on a hard, flat surface - you can sand them down to the proper size. It will get you out of a bind
3/3/2021 2:37:44 PM • Hammering • Answered on Mar 03, 2021
3answers
Is there any maintenance I can do on a Kango 950 Jack hammer
Ureythn GE00 is madr by Fuchs in Germany - see their website.
Darina is made by Shell - see internet for comparable grease
11/7/2019 2:23:42 AM • Hammering • Answered on Nov 07, 2019
How to troubleshoot the hammer if it vibrates excecively.... ??
no information generic answer --notify the manufacturer or owners manual for assistance
9/13/2019 6:28:41 AM • Hammering • Answered on Sep 13, 2019
Which type of oil for rok demolition hammer thank you
If an oil sight glass is in the modelrange of the brand ROK Rottela 40 , but if no sight glass is used in the model then often is to use special Grease lubrication. or only an special volume of oil and most used of them are zinc-free hydraulic based and included in the manual instructions of a maintenance set (service kit)wear parts set.
5/29/2019 9:53:04 AM • Hammering • Answered on May 29, 2019
I received my Xtreme Jack hammer 2200W Demolition Hammer. How much oil (quantity) do I put in and where do I fill it?
3 to 4 ounces for first fill. You actually unscrew the oil gauge with the little wrench that should have come with the tool and add the oil there. After putting the cap back on, hold the tool upright to check the oil level. Check daily and add oil when the level drops to 1/4 when checking as described above.
4/5/2019 5:17:26 AM • Hammering • Answered on Apr 05, 2019
Briggs & Stratton Breaker Point Plunger 298125 298125s Briggs  Stratton Logo
1 questions posted
Top Briggs & Stratton Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Hammering
Most Popular Question
condenser 8 hp briggs engine corroded
  • Hammering
