20 Most Recent
Dell Latitude ST 1.5GHz 2GB 64GB W7Pro 10" Tablet Refurbished LATST-64 Questions & Answers
Dell venue 3730 lockscreen bypass
Hardware Key Reset
If your device is not working because it is frozen then you wouldn't be able to reset it with the software. So the next option would be the hardware method.
1. Press and hold down the Power button + Volume down button + Camera button all at the same time until the device vibrates, now let go of the Power buttonwhile continuing to hold down the Volume down button and theCamera button.
2. Shortly you should see the message displaying "Are you sure you want to format?", you can now release the Volume down button + Camera button.
3. In the format screen you have the option to either Format or Cancel. Tap on Windows key Format if you are confident to go ahead.
4. Press on the Windows key again to confirm your choice.
Your device should now begin to format the device and shortly should startup with the Start-up Wizard. Ensure you device have the battery power while doing this
How do I hard factory reset dell venue8-3840 tablet
Your best bet is to google your specific device, but some have a small hole on the side and you can use a paper clip. Or power off, then power back on holding the power and volume down button down until a menu shows up on screen. You may have two or three options such as hard, soft, or recover reset.
