20 Most Recent Blaupunkt IDC-A09 5-Disc CD Changer Questions & Answers
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
10/16/2022 12:22:34 PM • Blaupunkt... • Answered on Oct 16, 2022
How to add an AUX port for connecting MP3 players to a car radio
try after market module or harness try find a after market supplier and see if avaiable
11/5/2019 3:41:28 AM • Blaupunkt... • Answered on Nov 05, 2019
IDC AO9 PSA, 7 607 769 050 LIGHTS FLASHING
some dust or even dirty sensors are causing this problem with a pressure air can you may solve it or better to take it to service bench
4/27/2019 7:07:45 PM • Blaupunkt... • Answered on Apr 27, 2019
2answers
I need a code from
try code 5112
11/27/2017 7:30:55 PM • Blaupunkt... • Answered on Nov 27, 2017
I removed my PU 2471A head unit and Blaupunkt
The head unit needs reprogramming with planet to accept the CD changer....... a main dealer or any good local garage should be able to help you with the software needed.
5/29/2017 10:38:53 PM • Blaupunkt... • Answered on May 29, 2017
Peugeot 307 5 stack cd player
hello hi ... umm first of all the cd player of that car has issues and its not only you who has faced it. secondly rather than spending $1500 get a new stereo.. its the era of usb, aux and bluetooth now
4/20/2017 3:51:19 AM • Blaupunkt... • Answered on Apr 20, 2017
0answers
Blaupunkt IDC A09
hi whats your email?
will email you.
mark
1/1/2016 5:10:42 AM • Blaupunkt... • Answered on Jan 01, 2016
My vz ss blaupunkt radio says voice in and wont
i had this problem in my ute, if you take out the glove box (simply pull it towards you) there will be a small panel on your right (if you are in the passenger footwell), it's located just to the left of the radio and has 2 small screws, if you remove them this plastic panel will be able to be pulled away and in there will be a unit that looks like a modem, simply unplug the power from this and the voice in problem will be gone! i disconnected mine completely and removed it.
10/24/2015 2:08:58 PM • Blaupunkt... • Answered on Oct 24, 2015
Hi,my cd player will not load or eject my c.ds and
It is probably the loading mechanism gears are either broken or something has jammed them up, possibly a cd got out of alignment. If your handy with tools and there is no warranty left on it (opening up your deck will void your warranty) then open it up and take a look. If you can, have the power hooked up to it. you can either have it in the car which can be a pain to work on, or get a 12 volt power supply and work on it on a desk. that way you can see what is happening. Depending on the problem you might be able to fix it. but with out seeing it for myself I cant help you any father. If you are not handy with tools then you will need someone who is. Chances are something is broken though and depending on the price of the deck it might not be worth paying someone to fix it. So if no warranty and not that expensive of a deck than go for it and open it up, you really got nothing to lose and you might learn a few things. Thats how I got started fixing things
6/8/2014 5:49:47 PM • Blaupunkt... • Answered on Jun 08, 2014
0answers
Idc a09
Be the first to answer 4/20/2014 3:25:28 AM • Blaupunkt... • Posted on Apr 20, 2014Be the first to answer
0answers
0answers
Blaupunkt IDC-A09 5-Disc CD Changer Logo
228 questions posted
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Blaupunkt Car Audio & Video
Most Popular Question
six cd changer 6 cds stuck inside none
  • Car Audio & Video
