I guess you are using tractor fed paper, the type of paper with holes down the side.
The problem you have is that the paper path has been changed on the
printer to the single sheet feeder rather than the tractor feed, you will need to change this back again via the control
panel, this is done something like this;
- Put the printer Offline
- Press Setup
- Press the button under PaperWay
- Change this to Tractor 1
- Press SET
If the above steps do not work disconnect the
printer from the computer then try again.
For more info see the Dascom web site;
http://www.dascomeurope.com/support2/technical_notes/serial_matrix/T2240/T2240_tn007.htm
And look for the
Online Single & Load section
