20 Most Recent
Black & Decker Black and Decker FIRESTORM 18v 18 volt hammer drill NEW Questions & Answers
How can I reverse the direction on the drill?
Above the trigger there is a black slide switch that will reverse the direction if its in the colckwise direction the richt side is pushed in if counter clockwise the left side is pushed in.
Keyless chuck overtightened
two strap wrenches work well becasue they will not crush or scratch the chuck like channel locks or any plier.
I cannot get one screw
You can take a drill bit around the same diameter as the head of the screw and drill the head out. It will get to a certain point and then break off. once you then seperate the housing you can take needle nose pliers and twist the rest of the screw out.
Where can I get a battery for Black & Decker Drill CD 1000?
This will be a suggestion...but for mine I bought two 18650 LiFePo4 cells (3.7V each) and replaced the original NiCd Batteries. It has been working for many years now, since the original batteries expired and stop working in 2002 (I bought the CD 1000 back in 1994!!!!!). You have to use a special charger for the new ones but they stay charged a lot more and the drill has more torque.
