20 Most Recent Hitachi Nip Service Kitoverhaul Kit For Dh38ya Questions & Answers
This hammer may not need parts replaced. If it has not been serviced in a while you may only need to take apart lower half of hammer and wash out old grease and replace with either hitachi, bosch, dewalt, or skil grease. You can even use some skil worm saw lubricant sold at Lowes. Just clean and lube more often. This hammer works with air cushions action. The motor moves the piston and air trapped between the piston and striker moves the striker against the second hammer. This system does not work well if the grease if too thick or dirty or if the hammer is stored with bit facing up in the air. If parts look well lubed then may be issue with bit or second hammer may be stuck. Do not use bits with missing pieces or that have been ground where the second hammer strikes. Parts that need to be replaced will be obvious. But generally clean and lube will do the trick. Good luck
Hitachi Nip ... | Answered on Oct 05, 2010
Try just stopping and starting the machine off a while.to see if the hammer appears.
Hitachi... | Answered on May 03, 2014
There is a sight glass on the side for you to see the oil level. Make sure they are always checked. You can buy the oil at any service center. Hilti makes oil too and can probably be purchased at Home Depots. Also the Home Depots that have tool rental programs would most likely sell the Hitachi oil too.
Hitachi... | Answered on Apr 24, 2012
For most climates a good oil to use is air compressor oil (mineral). Sold at Lowes and many other stores. It has great lubrication properties and can take good amount of heat. In very cold climates where oil could thicken, store hammer indoors to keep warm until ready to use. Good luck
Hitachi... | Answered on Jul 01, 2011
Hitachi sells a pneumatic oil for use in its air power tools. Your local Hitachi dealer, or any pneumatic dealer will sell the oil. The brand is not as important as using a few drops directly into the air fitting when starting a day of work. If used heavily, oil it again mid way through the working day.
Hitachi... | Answered on Jan 26, 2010
In most brands of this breakers there is no oil used , (only if there is an oil sight glass on it) some rotary hammers or breakers with high rpm have oil lubrication ( in most case its a sinc free hydraulic oil) (or special Turmopol oil (by Hilti) but this kind of hammers have no high rpm for oil and i think its having a normal grease lubrication and its enough for replace the grease after the carbon brushes are short and the tool stopped working then its time for service o-rings and seals and grease for the next service by the ALdi service.??
Hammering | Answered on Dec 02, 2019
Ureythn GE00 is madr by Fuchs in Germany - see their website.
Darina is made by Shell - see internet for comparable grease
Hammering | Answered on Nov 07, 2019
no information generic answer --notify the manufacturer or owners manual for assistance
Hammering | Answered on Sep 13, 2019
Hitachi Nip  Service Kitoverhaul Kit For Dh38ya Logo
2 questions posted
Top Hitachi Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
View Most Popular
Hitachi Hammering
  • Hitachi Hammering
Most Popular Question
parts need rebuild h45sb2 only
  • Hammering
