20 Most Recent
Rain Bird 4 Station Single Program Sprinkler Timer ISA304 Questions & Answers
Can i put two valves on one station
You should be able to put two valves on one station. If it is too much for the timer either a fuse or a "virtual fuse" on the circuit will fail. Just turn the unit OFF, separate the two valves and turn unit back ON to reset "virtual fuse".
I am an irrigation contractor and we have many timers with doubled zones.
Gary
I have low water pressure on my rainbird sprinkler
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
9/16/2015 8:12:51 PM •
Rain Bird...
Answered
on Sep 16, 2015
I recently left town for 4 days and did not set
CHECK THE VOLTAGE COMMING FROM THE TIMER TO THE VALVE WHEN THE TIMER IS IN THE ON POSSISTION IF NO VOLTAGE THE TIMER OR IF IT IS LOW VOLTAGE THE TRANSFORMER IS BAD. IF YOU HAVE POWER FROM THE TIMER THE COIL ON THE WATER VALVE HAS GONE BAD
11/21/2013 4:30:39 PM •
Rain Bird...
Answered
on Nov 21, 2013
