20 Most Recent Porter Cable PorterCable DBSI325 3250 Watt Electric Generator Questions & Answers
Voltage Too High
the generator is running too fast..since you are using a manual speed control it means you are overiding the automatic control,, just cut down the speed to where it gives the voltage you wish..or let the auto control work..
10/3/2017 10:09:01 AM • Porter Cable... • Answered on Oct 03, 2017
2answers
Leaks oil between the motor and the generator
bad seal or loose flange bolts
7/9/2014 8:13:05 PM • Porter Cable... • Answered on Jul 09, 2014
I have a new Yamahaportable generator, it works
A water heater is approx 4.5 KW too much for that generator, you pretty much asnwered your own quastion it is overloaded. Not to mention a water heater is resistive, not inductive thefore it is harder and you won't get a full3.2KW out your generator
11/18/2013 9:57:49 PM • Porter Cable... • Answered on Nov 18, 2013
DBSI325 will not put out voltage
Most of the problems like this are due to a failure of retention of the magnetic field to allow it to build up. Search Google for methods to "flash" the field. If you have had an accident of shorting or putting excessive load on the unit, rotating diodes of a brushless generator can be blown. Of the methods of flashing fields of the generators, I have had the most success with the method using TWO light bulbs in series between the utility mains and the generator. PLEASE be careful when doing this or handling electrical equipment where high voltage is present.
5/14/2012 8:32:19 AM • Porter Cable... • Answered on May 14, 2012
How much oil what wt.
Most any kind of 4-cycle motor oil like 10W-30 will work in these motors. After draining the old oil replace the drain plug. There are two types of motor oil fill holes: 1. If you have a motor with the oil fill/check hole on the bottom of the motor and a small screw-in plug either with or without a small dip stick on it; with the motor level, fill the crank case with oil until it is up to the threads on the oil fill/check hole. 2. If you have a motor with a long dip stick that goes into a filler tube at the top of the motor, again with the motor level, put in about half a quart of oil and use the dip stick to check the oil level. If not full, add quarter quart amounts and check again until the oil is at the full mark on the dip stick. Do not overfill the crank case with oil. Most motors will take about one quart of oil but it varries so watch to see the oil level come up to the proper level.
2/3/2011 10:50:17 PM • Porter Cable... • Answered on Feb 03, 2011
Porter cable CTE 300 OIL TYPE
The Porter-Cable CTE 3000 generator uses SAE 10W-30 motor oil.
3/19/2023 3:12:55 PM • Porter Cable... • Answered on Mar 19, 2023
My porter cable 7500 watt generator does not consistently produce 220 volts it fluctuates below 220 why is that
Usually dependant upon load and RPM of engine.
9/24/2021 6:33:38 AM • Porter Cable... • Answered on Sep 24, 2021
I have a porter cable generator CTE3000, need to know the type of oil to get thanks
You can contact your supplier who supply the generator to you. They know details about their product.
12/31/2019 8:50:10 AM • Porter Cable... • Answered on Dec 31, 2019
Where is the oil drain plug on a Porter Cable BSV550-W located?
What is a BSV550-W
6/11/2019 6:18:41 PM • Porter Cable... • Answered on Jun 11, 2019
Porter Cable BSV 750-W Brushless Generator does not shut off completely, it continues to idle low and sputter when attempting to turn off
Hello Karen, suggestion, when you turn off the generator, previously disconnects the electrical load that is feeding and verifies if it continues with the problem It could be in need of maintenance I sent you the link so you can download the user manual I hope you can solve your concern Greetings Franco Dosil Hola Karen, sugerencia, cuando apagues el generador, previamente desconecta la carga electrica que esta alimentando y verifica si sigue con el problema Podria estar necesitando un mantenimiento Te envio el link para que puedas descargar el manual de usuario Espero puedas resolver tu inquietud Saludos Franco Dosil Porter Cable BSV750 Instruction Manual
4/30/2019 4:54:48 PM • Porter Cable... • Answered on Apr 30, 2019
I have a porter cable generator BS1525 it is putting out 186 volts what is the problem is it the gs0873 compacitor?
Check engine speed first. It is likely too fast. If you have an ability to check frequency of output voltage, do so. It should be ~60hz in USA
10/17/2017 3:12:03 AM • Porter Cable... • Answered on Oct 17, 2017
Fuel flooding carb and getting in oil. What can I do?? 6500 watt 13hp porter cable
Overhaul the carb, make sure the float hasn't sunk and see that the brass valve attached to it is sealing completely in it's seat.
10/25/2016 2:40:08 AM • Porter Cable... • Answered on Oct 25, 2016
I need a capacitor for a porter cable DBS1325 alternator but it is rusty and I cant read the labeling
Porter-Cable Portable Generator - Lawn and Garden Manuals
lawnandgarden.manualsonline.com > ... > Lawn and Garden Porter-Cable Products 1 - 35 of 35 - Porter-Cable Portable Generator A02871-043-0. Porter-CableGenerator Instruction Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade ...Missing: dbs1325alternatorcapacitor
9/13/2015 12:17:21 AM • Porter Cable... • Answered on Sep 13, 2015
Have porter cable portable generator model h1000.it run for 2 min then shuts down.have replaced fuel pump and cleaned carb.at idle it runs longer but still cuts off.
Have you checked the oil level? Some newer ones have an auto-shutdown feature if it detects a low oil level.
1/18/2015 12:17:11 AM • Porter Cable... • Answered on Jan 18, 2015
H451cs carburetor
Either the fuel is old/bad or the carburetor needs cleaning very badly.
7/27/2014 4:09:44 AM • Porter Cable... • Answered on Jul 27, 2014
Porter Cable Generator does not produce electricity
Here are a a few possibilities to look at:
1) Bad connection at the outlets themselves (loose wire) regarding neutral, hot wires.
2) Bad Excitation Capacitor. The Exc. Cap. is responsible for energizing the field wiring of the alternator. If the field is not energized, there will not be a magnetic field developed, therefore, no electrical output.
3) Open Field / Stator winding. If Field winding is open, no magnetic field will be developed. If Stator winding is open, no voltage will be induced.
4) Generator speed is too slow. If the RPMs of the engine are too slow, the output of the alternator will fail as well. Note that from normal speed, voltage output will occur but at reducing frequency until ouput ceases altogether, usually at about 47Hz. If your alternator is a 2 pole, engine speed should be 3600 rpm nominal. If alternator is a 4 pole (most aren't), engine speed would need to be about 1800 rpm nominal.
5) Generator speed too fast. If RPMs are too fast, output may fail as well. See above.
6) Excitation Fuse has blown. There is sometimes a fuse in the excitation circuit. To check this, you will likely need to pull the end housing off the alternator. Pay attention to bearings / bushings.
2/12/2014 10:21:31 PM • Porter Cable... • Answered on Feb 12, 2014
Porter Cable PorterCable DBSI325 3250 Watt Electric Generator Logo
Popular Tags
8 questions posted
Top Porter Cable Electrical Supplies Experts
Jay Finke
Jay Finke
CJ Rock
CJ Rock
ADMIN Andrew
ADMIN Andrew
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Porter Cable Electrical Supplies
Most Popular Question
much oil wt
  • Electrical Supplies
