20 Most Recent
ViewSonic PJ500 Multimedia Projector Questions & Answers
My Viewsonic PJ500 , The
if this is a DLP projector then the light tunnel needs to be adjusted or replaced or the colorwheel index needs to be adjusted if what you are describing is ghosting of sorts.
If this is an LCD projector your green lcd panel could be burnt, or you could have true ghosting that needs to be adjusted with the options in the hidden menu and should only be done by someone who knows what they are doing.
Good luck
Can't get my Viewsonic projector to project an
Hold the FN+CRT/LCD or (it could be an icon/image of a screen) simultanesouly and then keep press the CRT/LCD key it should eventually get around to displaying an image on just the projector or projector and laptop screen
Trying to hook up PS3 to this projector.
Try a couple different things. First, ignore the Red/White for now
since it's audio and you're having issues with the video.
Try running the yellow from your pj to another source other than the
PS3. If you still have no video then you know it's a pj setting. If
you do get video then you know it's a PS3 setting.
Then maybe try another cable or adjust your PS3 settings
If that projector is not HD, then
Don't buy that projector, it's not HD. It may support 720p and 1080i
input, but the output is 800x600.
If you're willing to shell a
little more for HD, buy the Optoma HD70, a true 720p projector. It has a
connector of each type on the back (Composite, Component, SuperV, VGA
and HDMI), all that for less than 1000$
My 360 is connected to
one, and the picture quality is beyond awsome on my 120" screen. It
should be the same with your PS3.
Viewsonic PJ500 bulb does not come on
Hi.
Look at the base of the bulb at the filament in the center of the bulb, if buldging change he bulb first. If the porblem continues then have the units Ballast or Sometimes called the lamp driver check and replace if defective. The cheapest way is the check the voltage at the lamp connections in the housing for At least 280 volts, while turning on the unit you will need a voltage meter to do this.
The lamp continues to flash red lights for power and lamp
I have the same problem as posted too, ordered 3 new lamps and they all still do the same thing. I`m starting to think its the projector that has a problem. Anyone got a solution other then keep buying new lamps and try getting it to work... I mean, after 3, how bad lucky can you be that they are all bad lamps...
I have a viewsonic pj500 projector which has
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Pj500 veiwsonic
1. Switch the power on.
2. Hold the Reset Button down for three seconds until the lamp timer is displayed at the bottom of the viewing area.
3. Press the left arrow to select 0. Then wait for the lamp timer display to disappear.
Lamp Timer is now reset.
