20 Most Recent
Conair Ww39 Digital Glass Chrome Scale Questions & Answers
The conair ww39 requires 2 batteries. When replacing what direction do they go?
Hello (revised)Revision:If the batteries stack on top of each other, they have to all go in the same direction. Be sure the flat backs are in the direction toward the spring. The protrusion on the other end of the battery will face away from the spring.End revision.It is very common to use the following method.Look into the compartment and you will see a spring where each battery goes. Place the battery's flat bottom against the spring. Put the compartment cover back on and test your scale. If the batteries are good and the scale works it should be ready for you to use once again.Best wishes,Joe I’m happy to help further over the phone at
https://www.6ya.com/expert/mark_7bbaa7a1174e0903
How do you use a
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
How to adjust the power setting adjustment screw on a conair model hc200b hair clippers
The power setting adjustment screw on the Conair Model HC200B hair clippers is typically located on the side of the clipper near the on/off switch. To adjust the power setting, you will need to locate the screw and use a small screwdriver to turn it.
Here are the general steps to adjust the power setting on your Conair Model HC200B hair clippers:
- Locate the power setting adjustment screw on the side of the clipper near the on/off switch.
- Use a small screwdriver to turn the screw clockwise to increase the power setting or counterclockwise to decrease the power setting.
- Turn on the clippers and test the power setting by cutting a small section of hair.
- If the power setting is not to your liking, adjust it again with the screwdriver until you achieve the desired power setting.
It's worth noting that the power setting is usually a small screw and turning it too much can damage the internal machinery of the clipper, so it's best to make small adjustments at a time. And ensure the clipper is unplugged before making any adjustments.
