20 Most Recent Invacare Supply Group Invacare Pronto M51 Power Wheelchair Questions & Answers
2answers
Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
5/6/2014 4:00:13 PM • Invacare Supply... • Answered on May 06, 2014
Manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
[email protected]
5/28/2010 9:19:27 AM • Invacare Supply... • Answered on May 28, 2010
The wrench and left speed symbols are flashing
this is service manual https://www.manualslib.com/manual/867414/Invacare-Bora.html
8/31/2022 2:12:05 PM • Invacare Supply... • Answered on Aug 31, 2022
We have a pronto m51 and the amber light is on after we unplug it from the wall, and it won't move at all.
Hi flashing lights 8 times (Controller fault.). if the batteries haven't been used for several years U might have to replace them .U can buy a BATTERY LOAD TESTER OF E/BAY cost approx,$36..this will give U an accurate test on the condition of the batteries ,good luck 26346437-e5jkhq4oawb2rbtt3t2s2xlr-3-0.jpg
11/9/2016 11:22:38 AM • Invacare Supply... • Answered on Nov 09, 2016
What flash codes mean
They are diagnostic codes to help troubleshoot a possible problem with your wheelchair. The lights blink in patterns. You have to count the number of blinks and what color they are.
6/25/2015 3:42:40 PM • Invacare Supply... • Answered on Jun 25, 2015
24v dc motors can it run at all with 12vdc
Sure. Just slower. If you remove the motor from a power wheelchair to use in other applications keep this in mind; these motors are designed for PulseWidthModulation Speed Control (apx. 10kHz) with a feedback control to keep the speed more consistent. Feedback and pulsing is key to power and efficiency. If you run them at 12 volts without a pulse control the current to power output is much higher and the I*I*R (I squared times R) losses are higher - dissipated as heat. The motors will run very hot under a load with DC that isnt PWM'ed. If the use/cool down duration is short you should not have issues.
5/13/2014 8:24:40 PM • Invacare Supply... • Answered on May 13, 2014
My Invacare TDX SP has died on me and someone told me of a trip switch on the batteries..Anyone know where this switch is as all I can see are bolts and metal?
http://www.invacare.com/doc_files/1143190.pdf Owners manual for TDX SP link above. First check if you have power present at the charging port. If you have power (24 volts) then the batteries and wiring are not the issue. If you don't then check the battery post fuses. These are "L" shaped brackets with a white square fuse held on the positive post with a through bolt and nut. On older chairs these are known to become loose and or blow just when you need power or stop suddenly. Also check the big Anderson connectors at the power point at the end of the battery box. Check for solid connections. If there is 24 volts here to the control box, next check the controller connector. If there is +24 at the controller connector but 0 at the joystick charger port you have big issues. Either the traces connectors in the controller are fried or your joystick has major issues.
5/13/2014 7:54:19 PM • Invacare Supply... • Answered on May 13, 2014
Is it possible to reverse the drive lever on the
Hi Mark. Reversing the polarity:There are 3 wires on the Wig Wag Assembly. (reverse the wig-wag function) simply de-solder the 2 outer wires & swap their position & re-solder.I would seek a price for doing the job from an approved scooter repairer,unless you are comfortable doing the job yourself.I hope this has helped,Colin
12/28/2013 4:11:24 PM • Invacare Supply... • Answered on Dec 28, 2013
What oil is used in a Mercury M48 mobility scooter
hi, from experience i recommend you use a semi fluid type greasehttp://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=82915557&contentId=7022530From inspections , it's works best..... Oil will leak....Regards
11/19/2013 12:00:11 AM • Invacare Supply... • Answered on Nov 19, 2013
Please tell me the weight of my Gopha LX3/ eureka
theres a website called ask jeeves.com, go to it and ask question, wish i could help you.
9/7/2013 12:55:37 AM • Invacare Supply... • Answered on Sep 07, 2013
0answers
Wiring
most manufacturers will NOT supply you with that, very difficult to get, FDA has strict guidelines on who can repair and maintain power chairs. what is the problem with the chair
9/5/2012 7:18:02 PM • Invacare Supply... • Answered on Sep 05, 2012
Invacare Supply Group Invacare Pronto M51 Power Wheelchair Logo
6 questions posted
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
john h
Steve Pack
Steve Pack
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Invacare Supply Group Health & Beauty
Most Popular Question
hi i have a pronto m51 the yellow led in
  • Health & Beauty
