20 Most Recent Intex 2100 Gph 95 Hp Sand Filter Pump With Gfci () Questions & Answers
I bought the Intex 2100
these pumps should run 24/7 as they are SMALL, try contacting Amazon. see if you can get a replacement pump, pump only. also, see my tips and tricks keeping pool from turning green sam_0487-5wza5llwn2qwnlqvdjcvdeqf-3-0.jpg
6/8/2017 3:58:39 PM • Intex 2100 Gph... • Answered on Jun 08, 2017
Loosing pump suction when vacuum pool
keep out all the air inside the lines. When Pumps loose power suction is because there is some air inside the lines.exaust the air inside the lines
9/3/2014 3:47:36 AM • Intex 2100 Gph... • Answered on Sep 03, 2014
What do i doi have no pressurer on my pump what can i do
If you can hear the motor running and you are just not getting anything out of it or low pressure you will need to prime it. Pour water into it on the output side and that should get it going.
7/27/2014 3:03:37 AM • Intex 2100 Gph... • Answered on Jul 27, 2014
No pressure for the filter outlet.
it sounds like the filter is clogged somewhere
5/22/2014 3:08:06 AM • Intex 2100 Gph... • Answered on May 22, 2014
When I turn pump on all it does is make a low
it might have dirt/bugs in the switch, use a air compressor and blow out the back of the motor and light tapping with a screwdriver might spark it back to life
10/2/2013 4:56:37 PM • Intex 2100 Gph... • Answered on Oct 02, 2013
0answers
0answers
Need to put sand filter
Drain the water from the filter and pump housing. With the water out of the filter, you can now shore the filter near the pool or in your near by shed or garage.
9/27/2011 11:43:58 PM • Intex 2100 Gph... • Answered on Sep 27, 2011
My system has cracked two
- Too much pump for the filter
- Clogged filter / dirty filter restricting flow and building pressure
- Hose(s) too small a diameter
- Restrictions in or blackage of a return line
- Hoses connected to skimmer/inlet and return in reverse or incorrect order
- Problems with the filter valve not routing water correctly
- Bad pressure gauge misleading you on overall system pressure, again, clogged filter being the real issue
If it is none of those look at water chemistry being way off stressing the plastics or pool users climbing on the pump.
John
9/7/2011 6:29:37 PM • Intex 2100 Gph... • Answered on Sep 07, 2011
Intex replacement pump looks different
As long as the horse power matches your probally fine.
8/15/2011 7:12:59 PM • Intex 2100 Gph... • Answered on Aug 15, 2011
Intex 2100 Gph 95 Hp Sand Filter Pump With Gfci () Logo
Popular Tags
37 questions posted
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Intex Pool & Spa
  • Intex Pool & Spa
Most Popular Question
bought intex 2100
  • Pool & Spa
