20 Most Recent
Intex 1000 Gallon Swimming Pool Filter Water Pump () Questions & Answers
Intex pump flowrate drops
you may have a dirty filter. Check your filter to be sure. Remove the filter from the pool equipment and see if it runs fine for longer period of time. The filter would be the only restriction in your Intex system for water flow.Rod
US Parts Center
How to install the filter on the inside of the
I am not sure what you are asking because the filter is to be installed on the outside of the pool, not on the inside. The manual you got for the pool should show how to install it. If you don't have the manual then the main thing is to connect a hose between the skimmer port of the pool and the suction of the pump/filter and connect the return port through a hose to the return port of the pool. If you can't connect it then you are probable missing some parts. I hope this helps.
Ok my pool has a
if you can't get an answer, heres their toll free number Tel: (800) 234-6839
Hi- I'm a new intex above ground metal frame pool
You've gotta keep that annoying filter pretty darn clean to please the saltwater pump. I have to scrub my filters daily for this reason. What pump do you have? Mine is rated for 4000gph but I see Intex even offers support for pumps with as little as 500gph.
What does U16 mean on my intex hot tub
limited info generic answer u code doesnt show for intex their codes usually start with E this is a manual that has the trouble shooting on page 20 ------- https://www.manua.ls/intex/purespa/manual?p=1 --------- and pg 13 has the codes
