20 Most Recent Gibson Les Paul Studio Electric Guitar Questions & Answers
Nashville April 19th 1985 number 43
Gibson Les Paul... | Answered on Jan 29, 2018
What you need is a complete set up as your truss rod is out of adjustment and bridge is too low. Your local guitar shop can help you out for around $50.
Gibson Les Paul... | Answered on Jun 15, 2016
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Gibson Les Paul... | Answered on Apr 22, 2016
Is there a letter before numbers?
Gibson Les Paul... | Answered on Oct 22, 2015
Your guitar was made at the
Kalamazoo Plant, USA
approximately in: 1967
Gibson Les Paul... | Answered on Apr 26, 2015
You have a grounding problem. Verify your cable is good first, then open the guitar and look for broken wires. The electronic parts sit in a cavity that SHOULD be lined with CONDUCTIVE paint that acts as a shield and should have an electrical connection. You will likely find ground wires soldered to the back of the control pot cases. If you find a wire broken loose you have found the cause. There is usually a wire to the ground system from the metal parts.
Gibson Les Paul... | Answered on Feb 05, 2015
Try and find similar on to as a guide.
Unsung Plant, Korea
June 1998
Production Number: 1025
Gibson Les Paul... | Answered on Jan 27, 2015
Gibson Model Number request?
Gibson Les Paul... | Answered on Sep 27, 2014
I think that it is an 1981 the system works like this for certain ones but where it was made makes a difference if it is made in U.S.A. this is how it is dated your # is 82681563= 1st&5th digit =81 2nd-4th= the day of the year=268=September 25th 56 = the production line # of guitars made till then 3= the 3rd guitar made on September 25th 1981 so the next guitar made after yours would be 574 and the # would read like this 82681574 but remember it matters where it was made in what country I hope this helped you
Gibson Les Paul... | Answered on Aug 27, 2014
OK... Most of the guitars have a PAINTED on shielding in the well with the electronics. Sometimes the electrical connection to this is broken causing hum. Sometimes the connection is by way of the potentiometer shaft nuts and they spin and break the connection. This paint is conductive and often black know as aquadag. Use an ohmeter to verify connection.
Gibson Les Paul... | Answered on Oct 26, 2011
Replace the guitar cable with a better quality one and keep the guitar away from devices generating magnet fields like amps, etc.
Gibson Les Paul... | Answered on Apr 05, 2011
The bridge should be on two posts, both of them with knurling on the edge. These screw into the body of the guitar, allowing you to raise or lower the action of the strings. Turn them clockwise to lower the action, making sure to turn them the same amount, so as to keep the strings even. You WILL have to re-adjust intonation after this.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Gibson Les Paul... | Answered on Feb 11, 2011
Best help for this is on YouTube videos !!! Search guitar intonation (note the spelling)
Gibson Les Paul... | Answered on Nov 05, 2010
Here are some links for you:http://home.provide.net/~cfh/gibson5.html#lpc also http://www.gibson.com/Files/downloads/bluebook/GibsonElectrics.pdf I hope this helps.
Gibson Les Paul... | Answered on Nov 01, 2010
Is is stamped into the wood? Is "Made in USA" also stamped? You have the proper amount of numbers, and looks like it was made on the 60th day of 2002 in Nashville. For more information, go to:
http://www.gibson.com/en-us/Support/SerialNumberSearch/
Gibson Les Paul... | Answered on Jun 09, 2010
Probably in 1983
https://www.gibson.com/Support/Serial-Number-Search
but, call to confirm because guess what it says?
Gibson Banjos 1988 to present
Earl Scruggs Models
Standard:
Sequential production number, starting at 001
'49 Classic:
YY-RR
YY = Year of manufacture
RR = ranking number (starts at 01)
Golden Deluxe:
YY-RR
Flint Hill Special:
FH-YY-RR
Special:
ES-YY-RR
Style 250
250-TT-RR
Granada
YY-MM-RR
YY = Year
MM = Month
RB
RB### = sequential production number
All other models
S(S)-YYMM-RR
S(S) = style (excluding style 250 - see above)
YY = Year
MM = Month
RR = ranking number
Gibson Music | Answered on Nov 08, 2019
Gibson Les Paul Studio Electric Guitar Logo
Popular Tags
23 questions posted
Top Gibson Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Are you a Gibson Music Expert? Answer questions, earn points and help others
View Most Popular
Gibson Music
  • Gibson Music
Most Popular Question
harley davidson gibson studio les paul
  • Music
