20 Most Recent
Korg D3200 Studio Package Questions & Answers
As usual with the korg d3200 the locate buttons
If the buttons are just sticking at their sides in the panel, lube with a tiny bit of CRC 226 on a Q tip. Get the CRC226 at Home Depot in the electrical dept. If the button mechanisms have failed or plastic hinges have broken then replacement is only option. Losing 4 of these to same problem is RIDICULOUS... time to change brands.
I have a Korg D3200. I want to make a rhythm loop
do you have the owner's manual if not download it-there are /were you tube videos for what your trying to do- they helped me alot - when you plug your guitar into the guitar jack on channel 1 you can't use the xlr input 1at the same time in addition be careful not to blow the audio system there are no replacement parts for this system
Speakers for D3200
yes- check out the m-auduo studiophile speakers & there are other brands that are better depending on your wallet.
Have korg d3200. gray
Korg is a great company and when you contact them they will help you. They can tell you how to get the CD and/or how to download and burn it to your own CD. then you can boot up the device
We laid down 5 tracks
Somehow proper save and shutdown was not done. You said the magic word PANIC... That is a deadly word in this situation. So first thing like for lost files on a PC is to look around... carefully. LIKELY the files are still there, just under a different folder or imbeded in another project. These systems do a pretty good job of not letting one clobber their files without confirming AS LONG AS proper shutdown procedure is used or power doesn't fail. The five tracks you might have forgotten to save...but the other should be there.
