20 Most Recent Yamaha Msp7 Studio Powered Studio Monitor Questions & Answers
thats not what im talking about theres people that are geting free vips and i dont get how to get one!
Yamaha Msp7... | Answered on Oct 20, 2013
Power supply built in speaker box seems damaged and possibly a fuse or transformer got blown, local technician will check it by opening lower rear panel of speaker box and will replace blown part.
Hope these info will help.
Yamaha Msp7... | Answered on Sep 19, 2011
It is possible and depends on the length of cables you will need. If you are using a fairly long run of say 50 feet, I would put a DI box with "ground lifted" to convert from unbalanced to balanced. If the cables are short, then you can probably use a unbalanced 1/4 inch plug to XLR adapter and an XLR to XLR cable between the adapter and the speakers. The system should be safe and should NOT cause any damage. Remember to run the whole interconnected system from ONE receptacle or power source.
Yamaha Msp7... | Answered on Dec 31, 2010
Do the lights come on?
Have you tried the headphone output as well as the line output(s)?
Is the volume turned up?
Do you have it plugged in with the original Yamaha AC adaptor?
https://usa.yamaha.com/support/manuals/index.html?l=en&c=keyboards&k=DGX505
Owners manual in the link.
Yamaha Music | Answered on Nov 04, 2019
seems to be a standard acoustic setup to me. If it doesn't have all the string pins in it, you'll need to get some. you simply pull out the pin, put the string in, then wind it up on the machine heads (tuners) On this one you may need to put the strings through from the inside, I'm not sure about this particular model. I like a double wrap to start on the bass strings, but that's a choice I make. You could go with nylon strings, get ball end, they're easier to use than plain. It takes a bit of know how to do plain, thy have to be wrapped just right on the pins.
Yamaha Music | Answered on Nov 02, 2019
You may find one if you google it.
Yamaha Music | Answered on Oct 27, 2019
Hi
If you are talking about cleaning the rubber contacts I wouldn't bother. Once they start to fail then it is best to replace them. You can do this either for the octave giving problems or best to replace complete set. Main part is VY84670R your piano has 6 octaves of these. with a shorter part at either end.
Yamaha Music | Answered on Oct 24, 2019
Yes you may use it as stand alone piano. Usually everytime you will power ON any yamaha psr model piano will appear as default voice.
Yamaha Music | Answered on Oct 19, 2019
try www.amazon.com,
Yamaha Music | Answered on Oct 06, 2019
This should help you trace the wires
Yamaha Music | Answered on Sep 27, 2019
Hi
the blue screen with lines is normally as a result of the ribbon cable which has contacts on failing.
The remedy is normally to replace the simple the screen assembly the parts for this are around £300 but there would be significant labour to add to this.
i would suggest talking to a local Yamaha technician
Becketts Music Ltd
Yamaha Music | Answered on Sep 17, 2019
Hi
the first thing to try is a factory reset
hold down the highest note while you turn the keyboard on.
once it has started up try again.
if there is only a faint sound when played it could be that the main amplifier has failed or that the speakers have become unplugged from the power board.
does it work on headphones correctly, if it does it points to an amplifier problem.
report back if the reset works
Dan
Becketts Music Ltd
Hello Rastorbator, since you think it is in perfect condition, spend a little more time and search the Internet, some People Forum that like these devices and offer them
Someone will do something for him and open less garbage
Greetings Franco Dosil
Hola Rastorbator, ya que estimas que se encuentra en perfecto estado, dedicale un poco mas de tiempo y busca por Internet, algun Foro de Gente que les guste estos aparatos y ofrecelos
Alguien hara algo por el y abra menos basura
Saludos Franco Dosil
Yamaha Music | Answered on Sep 06, 2019
Try a master reset to start with.
Turn keyboard off
Turn on whilst holding down highest note on keyboard
Once screen display has complete release key
This will reset to factory settings.
If this doesn't work report back and we can maybe try other solutions.
Dan
Becketts Music Ltd
Yamaha Music | Answered on Aug 23, 2019
if you have a technique you may have to untie it and fix the keys.check any guest things on the keys.
Yamaha Music | Answered on Aug 20, 2019
I am sure that information from https://essayholics.com/write-my-paper will help you to write your paper. I had such experience so I know what I am talking about
Yamaha Music | Answered on Aug 18, 2019
Yamaha Msp7 Studio Powered Studio Monitor Logo
6 questions posted
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
like transform yamaha msp 7from 110v
  • Music
