20 Most Recent Peavey Xr 8600 8 Channel Powered Mixer Questions & Answers
2answers
I have a Peavey amp but no sound is coming out?
Bad output transistors or bad Soldier joint in output section
11/27/2022 5:12:53 AM • Peavey Xr 8600 8... • Answered on Nov 27, 2022
PEAVEY XR 1600D Powered Mixer Desk, POWER CORD REPAIR.
That is standard UK wiring. Brown in Live. Blue is Neutral / Return. Green with Yellow stripe is Earth / Ground. https://www.google.com/search?q=peavey+xr+1600d+wiring+diagram Manual https://peavey.com/manuals/80301359.pdf ..
1/4/2022 6:31:08 PM • Peavey Xr 8600 8... • Answered on Jan 04, 2022
WHAT SIZE OR PART NUMBER FOR THE 2 FUSES FOR PVI4B MIXER
5 amp fuse in tray located at the back of the amp just above the power connector.
3/19/2019 12:34:17 AM • Peavey Xr 8600 8... • Answered on Mar 19, 2019
Have a Peavey XR 8600 we use it with 4 speakers in a riding arena. It works for a few minutes and cuts out.
It depends on if this is a new problem on a previously working system , or if it's been going on since it was first plugged in, but geneally speaking it sounds like your impedance load is too low on the amp and it's overheating. I would double check that, but if the load is in line with the specs, it needs to go to the shop. Contact Peavey to get the autorized repair guy in your area, or you can send it to them to do inhouse repairs. They are reasonable and have access to all the needed parts, but you'd have to pay to ship it in and back. https://peavey.com/support
10/18/2016 4:00:15 PM • Peavey Xr 8600 8... • Answered on Oct 18, 2016
XR8600, connected to 115xt bass bins and crossover out to Pro 15s (all 4 ohms). Left side muffled then died. Later, right side cut out several times. Then power lost. What might the fault be?
I suspet you have it connected in such a way that the ohmage the power amp section is seeing is toolow cauysing it to overheat and then fail.
6/28/2015 12:30:26 AM • Peavey Xr 8600 8... • Answered on Jun 28, 2015
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
6/23/2015 3:50:08 AM • Peavey Xr 8600 8... • Answered on Jun 23, 2015
My mixer works but volume levels are very low regardless of level settings or wether in main main or main monitor what would create this
The first thing I would do is get some CRC contact cleaner at Home Depot and give a qick squirt into both of the p
3/11/2015 9:48:56 AM • Peavey Xr 8600 8... • Answered on Mar 11, 2015
Peavey amp
Most likely a power supply problem. Take it to the repair shop.
1/20/2015 5:09:19 PM • Peavey Xr 8600 8... • Answered on Jan 20, 2015
2answers
How do I hook up the speakes with 1 main main and one main monitor?
Need more info, how many main speakers and monitor speakers are you trying to plug into the unit?
1/16/2015 8:25:58 PM • Peavey Xr 8600 8... • Answered on Jan 16, 2015
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock. 2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq. 3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume. 4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
1/13/2015 2:32:55 AM • Peavey Xr 8600 8... • Answered on Jan 13, 2015
I only have a vintage Peavey XR600B and I want to connect and ipod and ipad up to it so I can play music. Can I do this or do I need special cables?
Sure you can, but that mixer amp is a mono amp instead of stereo. Head for radio shack and get an 1/8" stereo male phone jack to 1/4" female mono adaptor. Plug the adaper into the headphone output of your device. Then run a shielded cable with 1/4" mono phone plugs on both ends (like an electric guitar would use) from the device to one of the channels on the Peavey. Bring the volume up on both the channel and master on the amp up maybe 1/3 the way. Play a track on your device and adjust the devices out put as high as it will go with out distorting the channel input. Then adjust the amp's channel and main output as you would normally to get the final volume you need.
12/15/2014 6:30:48 AM • Peavey Xr 8600 8... • Answered on Dec 15, 2014
Peavey XR series 600 may have been left on without one speaker plugged in, what is the likely diagnosis?
Out put amplifier is defective. If it was protected by a fuse - then look for a fuse that is blown.
11/17/2014 5:00:04 AM • Peavey Xr 8600 8... • Answered on Nov 17, 2014
My amp may have been left on with one speaker unplugged and is now not working. What's the likely diagnosis?
does the speaker still work? use a 9 volt battery and do a test thump to see if the horn and woofer still work...when the power amps on these units fail most of the time they shut down.
9/27/2014 8:20:59 PM • Peavey Xr 8600 8... • Answered on Sep 27, 2014
Low noise out of main monitor
like feedback???
9/20/2014 4:36:57 AM • Peavey Xr 8600 8... • Answered on Sep 20, 2014
Peavey pvi8500
first you have to have bluetooth on the Ipod
9/20/2014 4:23:27 AM • Peavey Xr 8600 8... • Answered on Sep 20, 2014
Hello, I am new to forums, this is my first time. I have a Peavey 696f power mixer, last night the left speaker channel stopped working, what do you think is causing this problem?
the pa1 or the pa2 input jack on the front of the unit is dirty, or you have a cracked solder somewhere, as these units are gettting old.
9/20/2014 4:05:45 AM • Peavey Xr 8600 8... • Answered on Sep 20, 2014
How do I connect an ipod or ipad up to a vintage peavey xr600B?
headphone out put to 2 unused 1/4 in channel inputs,,
9/20/2014 4:02:51 AM • Peavey Xr 8600 8... • Answered on Sep 20, 2014
Peavey Xr 8600 8 Channel Powered Mixer Logo
76 questions posted
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
peavey xr 8600 use 4 speakers in riding
  • Music
