20 Most Recent
Peavey Pv 20 USB 20 Channel Mixing Board with USB Input Questions & Answers
Why do I have crackling and hiss in one channel
If it is making noise as you describe with nothing plugged into the channel and without moving the controls, it needs to go to the shop. You should contact Peavey to discuss the problem. Here is a link to their support page-
Peavey com
And here is their Service Center locater page-
Peavey com
I just purchased
I would expect the numbers are on the installation disc, not the hardware. Also check labels on the original box it came in.
Peavey 14 bt mixer won't pan. Keeps sending signal to both outputs
If your Peavey 14 BT mixer is not allowing you to pan the audio signal and is sending the same signal to both outputs, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can take to address the problem:
1. **Check the Pan Controls:** Make sure you're using the correct pan controls for the channels you're trying to pan. The pan controls are typically knobs labeled "Pan" or "Balance" on each channel strip. Ensure that they're set to the desired positions.
2. **Reset Pan Controls:** If you've already adjusted the pan controls and they're not working as expected, try resetting them to their center positions. This can help eliminate any accidental settings that might be causing the issue.
3. **Channel Routing:** Some mixers have routing options that can affect panning. Check if there are any routing switches or buttons that might be affecting the signal routing for each channel.
4. **Mono/Stereo Mode:** Some mixers have a mono/stereo mode switch that can affect panning. Make sure the mixer is in the appropriate mode for your setup.
5. **Master Pan Control:** Ensure that the master stereo output pan control is set to the center position. If it's panned to one side, it can affect the overall stereo output.
6. **Test Different Channels:** Try panning different channels to see if the issue is specific to one channel or affecting multiple channels.
7. **Firmware/Software Update:** If your mixer has digital components or software control, check if there are any firmware updates available. Sometimes, software updates can address functionality issues.
8. **Physical Damage or Wear:** Inspect the pan controls and associated circuitry for any physical damage or wear that could be causing the issue.
9. **Factory Reset:** If none of the above steps resolve the issue, you might consider performing a factory reset on the mixer. Be sure to back up any important settings before doing this.
10. **Professional Service:** If the problem persists after trying these steps, it might be a more complex internal issue that requires professional servicing. Contact Peavey's customer support or a qualified audio technician for further assistance.
Remember that the exact steps and controls can vary depending on the model of your Peavey mixer. Refer to the user manual for your specific model for more detailed information on troubleshooting and operation.
8/20/2023 2:15:59 PM •
Peavey Music
Answered
on Aug 20, 2023
Does the peavey xr-600b have phantom power
It does not have built-in phantom power. Phantom power is a method used to provide power to condenser microphones and other devices that require a small amount of power to operate.
It is important to note that the XR-600B have XLR inputs which are typically used for condenser microphones that require phantom power but it does not provide this feature. If you want to use a condenser microphone with the XR-600B, you'll need an external phantom power supply or an audio interface that provides phantom power.
1/12/2023 8:34:18 PM •
Peavey Music
Answered
on Jan 12, 2023
Peavey bass R1080052 looking for any info .
Peavey R1080052 is a bass guitar model produced by the Peavey company. It is part of the company's Classic series of instruments, which are designed to offer vintage-inspired tones and aesthetics at an affordable price. The R1080052 features a solid ash body, a maple neck with a rosewood fingerboard, and two single-coil pickups. It also has a vintage-style bridge and a set of open-gear tuners. This bass is known for its warm, punchy sound and comfortable, easy-to-play feel.
1/10/2023 12:11:58 AM •
Peavey Music
Answered
on Jan 10, 2023
Peavey decade manual
Recommend an Ashdown or Fender with a 15" speaker, they will give a good sound, are gig-worthy, and will last. I use a Behringher 120W for rehearsal work, it only has a 12" speaker and thus cannot give a good 'presence', also I have been reliably informed, a lot of custom chips are used in thier amps. Don't forget, a bass 'E' goes down to something like 60Hz, and a good speaker and amp are a must for bass work
12/11/2021 8:17:54 PM •
Peavey Music
Answered
on Dec 11, 2021
