20 Most Recent
Toshiba e-Studio162D Copier Questions & Answers
How to reset maintanance message of sharp-ar 5127
U need to enter stimulation mode:
"C" key->Auto/Text/Photo key->"C"key->Auto/Text/Photo key
*perform above 4 key strokes quicky
Once inside stimulation mode, enter main code "20", then sub code "01" for maintenance counter clear, press "START" key to clear.
9/20/2019 4:51:10 AM •
Toshiba...
Answered
on Sep 20, 2019
I have a toshiba EStudio 162 error message L100-00 how do I fix
Hi:
If the error code is an L-1 the most lokely cause is the scanner lock on your machine is engaging with the scanner assy. Bend down and look at the left front corner of the copier right inside of the area where you grab your copies. You should see a clear round plastis knob. This has to be in the fully unlocked position If it is partly turned then this can be stalling your scanner assy and throwing the error code your seeing.
Good Luck
Andrew
2/24/2017 3:41:50 PM •
Toshiba...
Answered
on Feb 24, 2017
My canon printer iR2018- error
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty.
- Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
12/11/2013 7:20:47 AM •
Toshiba...
Answered
on Dec 11, 2013
Error code H2-00 on e studio 162d?
u have a dirty thirmistor in fusr unit.first clean it.then do this procedure.press clear key,auto photo key,clear,auto photo key in a sequence.copier will go dead .when display goes dead just press 14 start key.copier will take few second and will bi ok.by MIAN AKHLAQ
10/24/2013 9:24:50 AM •
Toshiba...
Answered
on Oct 24, 2013
Error f5 02
If it is a sharp it is code for exposure lamp...
10/16/2013 12:27:53 PM •
Toshiba...
Answered
on Oct 16, 2013
Sharp AR-5127 H2-00 code reset
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
11/20/2012 9:21:57 PM •
Toshiba...
Answered
on Nov 20, 2012
I can't get my toshiba estudio 162 copier to print 8.5 by 14 inch copies. how can i change the length?
Drawer feeding:A3, A4, A4-R, B4, B5, B5-R, LD, LG, LT, LT-R, FOLIO, COMPUTER, 13"LG, 8.5" x 8.5", 8K, 16K, 16K-RBypass feeding:A3 to A5-R, LD to ST-R, FOLIO, COM-PUTER, 13"LG, 8.5" x 8.5", 8K, 16K, 16K-R
7/14/2012 1:54:51 PM •
Toshiba...
Answered
on Jul 14, 2012
Pale copies and two vertical white streaks
I'm afraid that regarding pale copies, you are better off checking your consumables (toner, fusers, etc) and then try talking to Toshiba. However, the vertical white streaks can be caused by excess ink and other contaminants on the inside of the printer. If you open the main door to both the printer and finisher (if fitted) and look at all of the visible runners, feeders and other handling devices, try to see if any of them line up with your vertical streaks on a page. If so, try manually rolling them and cleaning them thoroughly. This might help remove some of the streaking (it did on mine).
Hope this helps,
Alistair
2/28/2011 11:37:37 PM •
Toshiba...
Answered
on Feb 28, 2011
