20 Most Recent
Toshiba E-STUDIO 850 Copier Questions & Answers
COPIER ERROR CODE C470
There is no C470 code but if it is in that range it is likely a fuser Call for Service.
You
can try going into (08) mode by holding 0 and 8 while turning on the
copier. Once the copier starts up key in 400 and press start, input "0"
and press interrupt. Try rebooting the copier, if this doesn't clear
that call for service then you are going to need to get work done on
your fuser.
Error toshiba e720 c370
Segun El Ribbon de toshiba me dice que la tarjeta de SyS es igual de la toshiba E-455 a la de la E-855. El problema es como hago la transformacion de version 455 a 855 . Mi pregunta es como hago o cual es el procedimiento . Gracias
Code set in 60-day trial e850
Hi how are you this is jack.... (
[email protected]).
Dear you On your copier 08 mode and press 673 and change the 673 value 254 to 60.. OFF Copier.. and simple ON..
Your copier 60 days trial perid has been ON.
PLEASE VOTE ME .
Thanks .
Best Regards,
