20 Most Recent
Toshiba E-STUDIO 720 Copier Questions & Answers
HDD Failure
The HDD ( Hard Drive ) is mounted on the back of the copier behind the rear cover. It looks like a regular hard drive from a computer. It sounds like your hard drive has crashed. It will need to be replaced. You can try to disconnect & reconect the hard drive... Good Luck
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
My toshiba copier720 error cf70 pls help me to solve this problem
That is a new toner motor abnormality. If memory serves there was a field mod released back when those were state of the art that dealt with that error code. Either way, sounds like you either have blown or about to blow your tonor motor. Time to holler at your nearest Toshiba Certified retailer.
Appears cf70 by starting machin
[CF70] New toner transport motor abnormalityCheck if the transport auger and paddle are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit).Is the new toner transport motor disconnected?Replace the new toner transport motor.
Hi! I use Toshiba eStudio
on the toshiba machines you can activate a trial period for printing and scanning without the print/scan dongle this is what you are seeing
''toshiba e-studio 720 displayed error
you can try switching the machine off hold in 0-8 till the machine beeps then push 400 start set the value to zero and enter reboot the machine and if doesnt6 work change the thermisters and check the thermastats
