20 Most Recent
Audio Technica AT2035 Professional Microphone Questions & Answers
I have tried running my
This mic has a 10db pad or attenuator switch at the base of the barrel maybe you clicked it on by mistake,
Try changing the lead.
The power supply on you preamp may be failing or had the voltage selector also clicked to the wrong setting.
These are cheap things to try before spending money.
Hi i am using the
This mic has a 10db pad or attenuator switch near the bottom of the barrel... make sure you haven't accidentally engaged it.
If that's not.... it try changing the lead. Also the power supply on your preamp could be failing.
These are a few cheap things to try before spending money for fixing.
Audio technica at 120 cartridge will fit my project essential?
Having looked at the turntable it seems to mount the cartridge with two bolt like fittings. The Cartridge you want has two mounts on the side that will take those bolts.
You will have to adjust the arm to compensate for the weight differences between the two cartridges, but once done it should play fine.
