20 Most Recent
Behringer C1U Microphone Questions & Answers
How do I get my Behringer C-1U mic to work?
I'm having the same problem, however I can say that Phantom Power is out of the question. the c-1u is a variation of the c-1. The difference is that the u doesnt require phantom power
Why Behringer C1U not recognized ?
Did you install the mic's drivers before plugging the mic in? Have you tried it on 32bit operating systems other than Win 7? I don't think it will be an audio driver problem ie: asio4all. But because the OS doesn't recognise the driver automatically it might indicate where the problem lies. I am not familiar with this particular mic ( I use AKG cs1000s with Zoom R16 audio interface ) but I know there can be issues with some 64 bit systems and certain audio hardware. Nothing in the Behringer forums?
I have a Behringer Mic
How to Operate a Behringer C-1U
The Behringer C-1U is a USB condenser mic for recording individual instruments. A condenser microphone is a mic that uses vibrations produced by sound to change the distance of internal plates that produce signal. Condenser mics typically require an extra change, known as phantom power, to operate. Since the C-1U is USB powered, phantom power is not needed. The Behringer C-1U has a frequency response that favors sounds around the 10KHz range. This heightens the clarity of recorded signals due to the microphone's treble boost.
Things You'll Need:
* Computer with USB 2.0 port
* USB cable
* Recording software
Instructions
Turn on the computer. When the operating system loads, connect the microphone.
Install any necessary drivers for the C-1U. This will happen automatically when the device is connected.
Select the Behringer C-1U as an input source in any desired audio software. In Windows, click the "Volume" icon in the task bar to open the mixer. Select the C-1U as the primary input. On Macs, use the "Audio/MIDI Setup" in the "System Preferences" menu to select the C-1U as the primary input
Note: make sure you activate the phantom power on the mic. That's the only way to power up the microphone.
Have a nice day.
I have a mic Behringer
You will need to turn on the phantom power which will be a switch labled eithe PHANTOM or +48V to use the condenser mic. YOu MUST use an XLR to XLR cable.
Please help! Behringer KX1200 master volume stops past 4 and no lines work just fx return
Also how do I reconnect the fan?
It sounds like you may have a broken potentiometer (aka volume knob) for the master volume control. If that is the case, you would need to replace it with a new one (or take it to an electronics technician to diagnose and repair).
Regarding the fan disconnection, this likely isn't causing your issue but you would still want to reconnect it as it keeps your amplifier cool while in use. Reconnecting is fairly straightforward - all fans have 2 or 3 wires that connect to corresponding terminals on the amp. Just make sure you don't mix up which wire is positive and negative, and make sure they are connected firmly and securely.
Behringer EP1500 amp does not produce full loudnes
Please test the loudness of your device with a third-party decibel meter. This will give you a clear measure of whether the loudness of your device is changing with increase in volume. It could be that your surroundings are absorbing the increased sound.
Thank you.
