20 Most Recent Tunturi T60 Folding Treadmill Questions & Answers
2answers
T60 treadmill came up with lift motor error so
power off, put in the key, press and hold down the stop button and incline up buttons, power on holding down the buttons for a few seconds - message clears
1/24/2021 6:11:56 PM • Tunturi T60... • Answered on Jan 24, 2021
Put a Tunturi t60 control motor board back together
What do you want to know . Send a pic if u like and I will tell you how . Darren
8/14/2017 11:02:06 AM • Tunturi T60... • Answered on Aug 14, 2017
0answers
The machine just goes into auto calibrating on the
power off, put in the key, press and hold down the 'stop' button and 'incline up' buttons, power on holding down the buttons for a few seconds - message clears
7/27/2014 5:29:23 PM • Tunturi T60... • Answered on Jul 27, 2014
0answers
System check failure
You can completely switch off the power for a few minutes and there is also a 'reboot' button at the front/bottom of the treadmill that needs to be pushed for about 5 sec (check manual). In my case that did not work and I had to replace the complete control panel/dashboard. My problem was different, I got funny messages about errors and flashing numbers on the dashboard. Tunturi was helpful in getting me the necessary spare parts. Good luck.
3/31/2014 10:23:37 AM • Tunturi T60... • Answered on Mar 31, 2014
Not working after initial start up.
is the new outlet the same as the old or did you put a adapter on the plug? sometimes if the machine does not "feel" the ground, it wont come on.. its a safety thing..
3/8/2014 9:44:59 PM • Tunturi T60... • Answered on Mar 08, 2014
I have a tunturi t60 and it as stopped working and says data transfer error on display
Dear Sir:LUBE inmediately the machine, the problem is lack of maintenance, maybe you have deck belt worn, that produce enough friction and by consequence shut down the machine.2) Lube the rollers bearing in according with the instr.manual schedule.3) Measure the voltage motor, if there are voltage the motor need repair or replace.4) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.5) Run the software calibration for diagnose, and troubleshooting.See my personal tips for help.sincerely. God bless you.
11/3/2013 4:24:44 AM • Tunturi T60... • Answered on Nov 03, 2013
Treamill shows' Motor Overload' after a couple of
see the video attached. lube the rollers brearing front and back too.test the terminal motor voltage with VOM, if there are the motor is faulty. test the output voltage control board for input voltage terminal motor, if there are NOT voltage the board is faulty. See my personal TIPS.God bless you
10/11/2013 11:51:27 AM • Tunturi T60... • Answered on Oct 11, 2013
0answers
ELEVATION RAISED AND STOPED
pleae RUN inmediately the software caibration for diagnose, troubleshooting, fix it.LUBE the gear and shaft elevation motor, see the diagram2) test the elevation motor, see the instruc.God bless you7_21_2012_12_13_24_pm.jpg7_21_2012_12_13_43_pm.jpg
7/21/2012 12:13:51 PM • Tunturi T60... • Answered on Jul 21, 2012
How to display kph instead of mph
6/27/2012 10:37:53 PM • Tunturi T60... • Answered on Jun 27, 2012
Speed sensor error will show on the dispaly and comes to a stop
ADJUST THE SPEED SENSOR:Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.ADJUST TOO: 1/8" THE SENSOR SWITCH SEE THE DIAGRAM.11_29_2011_3_41_23_pm.gif11_29_2011_3_41_40_pm.gifSee the block diagram for any treadmills. how the main controller board has the aprox 90% of function. You must finally test the Main C.B.Sincerely.E.CUADRA
11/29/2011 3:42:59 PM • Tunturi T60... • Answered on Nov 29, 2011
Treadmill not turning and has caused power cuts.
if power comes and goes you have a loose connection or a bad board
2/28/2011 8:05:36 PM • Tunturi T60... • Answered on Feb 28, 2011
Belt seems to be slipping
As a general rule, the belt should be kept as loose as possible. However, the belt must not slip on the rollers in normal use. Possible overtension can be quickly checked by walking on the belt at a speed of 3 mph The belt must slip on the front roller if you brake the belt with your feet, holding onto the hand rails, while you walk. If the belt does not slip, the tension is too high and the rear roller must be loosened. The belt tension and alignment is done by adjusting the rear roller position with the attachment bolts at the back of the treadmill a 1/4 turn at a time until correct tension attained. T
5/14/2010 6:10:03 AM • Tunturi T60... • Answered on May 14, 2010
Tunturi T60 Folding Treadmill Logo
24 questions posted
Top Tunturi Exercise & Fitness Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Tunturi Exercise & Fitness
Most Popular Question
display kph instead mph
  • Exercise & Fitness
