20 Most Recent Avanti Fitness AT380 Treadmill Questions & Answers
It's eithe a problem with the speed sensor or the motor controller is bad.
Avanti Fitness... | Answered on Aug 02, 2017
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. Check for treadmill error codes
Avanti Fitness... | Answered on Mar 13, 2016
http://www.manualsnguides.com/results.php
www.iconservices.com
http://fitness.manulsonline.com
http://manualsfactory.com
since this place you must not find the exactly model, you must pay in some of them, and download something similar.
The problem is the factory is coming in australia, and there are not service in USA, and support. sincerely.
Do not waste your time searching in the WEB.!
E.CUADRA
MANAGUA NICARAGUA
Avanti Fitness... | Answered on Nov 20, 2013
f91790db-4de9-486c-b68a-34e9745503d7.gifplease download the owner manual for identify the REED switch. go www.fitness.manualsonline.com
God bless you
Avanti Fitness... | Answered on Jun 16, 2013
556a61de-db92-4886-91ce-2e6c36b807f6.gifyou must LUBE the deck belt, front rollers and rear. This happen because the electronic system , shut down for to protect the system.
see the video and proceed according. See the diagram for REED switch clean it, test for open or faulty, tight the connector very well.
God bless you
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_12_46_08_am.gif
Try to tight the keypanel flexible cable vs Display Board and then tight the connector from display board vs Main controller board(lower board) and will be a good idea spray with contact cleaner the keypanel with carefully and patience.
Finally you will have 2 options if the problem persist: 1) display board faulty or 2) main controller board faulty. See. the block diagram how the main controller board has 90% of function in any treadmills.
ADJUST THE REED SWITCH ACCORDING WITH DIAGRAM.
NOW TIGH THE FLEXIBLE CORD FROM KEYPANEL VS DISPLAY BOARD AND THEN CONNECTOR FROM DISPLAY BOARD VS LOWER BOARD OR MAIN CONTROLLER BOARD.
11_30_2011_12_40_41_am.gifIf you can open the keypanel and clean with contact cleaner will be a good idea with carefully and patience. sincerely.
Finally if the problem persist you will 2 options: a) faulty display board and 2) Main controller board.
E.CUADRA
MANAGUA, NICARAGUA
Avanti Fitness... | Answered on May 16, 2013
take the hood cover with screwdriver or allen hex in front and rearGod bless you
Avanti Fitness... | Answered on Apr 08, 2013
is simle only take out the screw in front and rear from the Hood cover there are screw with screwdriver or allen hexGod bless you
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you
Avanti Fitness... | Answered on Apr 04, 2013
Avanti Fitness AT380 Treadmill Logo
37 questions posted
Top Avanti Exercise & Fitness Experts
robert
ray gallant
Tom Chichester
Are you an Avanti Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Avanti Exercise & Fitness
Most Popular Question
avanti 380 gets error code 68
  • Exercise & Fitness
