20 Most Recent
C3RS727LCD 4Channel Alarm with Remote Car Starter and Two Way AM Questions & Answers
I have an autopage alarm
Some fixya user told me a website
reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed.
you can go there and try free
Car will not start with remote starter.
There could be several reasons that your remote starter is not working. It could the hood shutdown pin. Push and hold the pin while starting with the remote. It could be a remote starter control switch in the off position. Did the unit ever work?
Alarm led indicator wont stop flashing unless i unplug the 12+ wire
Most alarm indicators have an LED that flashes as a theft deterrent. It says "Hey shady guy, this car has an alarm." The 12+ wire is possibly power to the whole alarm (depends on where you're unplugging it), so unplugging it might be disabling the alarm. The light is most likely operating as intended and uses VERY little power so it won't drain your battery unless your car sits for weeks at a time.
Somehow buttons seem to have
Turn ignition on, hold the red valet switch down for 2 seconds. Then turn ignition off. Your system is in VALET mode.
The remote start and alarm system will not work when in valet.
So the big one with the screen on me took a ****
Hello my name is Israel and I will help you. You can still use the alarm but you will have to do a couple of steps. Enter the vehicle. The alarm will sound. Insert key and turn to the 'run" position. Push or set the override button and alarm will turn off. The remote should be easy enought to replace. If you want to replace it, let me know and I will try my best to get a remote for you. Good Luck.
I think my brain burned
disconnect the 5 pin harness, it has a red, brown, black, white, and red/white wire on it.
the brown wire in that specific harness, is actually the wire that runs to the sirens RED wire.
