20 Most Recent
Kyocera Jax Cell Phone Questions & Answers
Www.kyocera-wireless.com/support
I can't call on my phone or it just doesn't work at all and I can't get threw to your company to find out what the problem is please help !!!!
Language settings
Just click on all the languages until it's in English. If you do that you will eventually get it back into English.
My phone has no power even when plugged in
Remove your battery, rub golden points with an eraser..and then place it again. make sure the black marks on the golden points have reduced and there are no leftover from the rubbing which get into your phone.
Otherwise:
Charger port might have stopped working.
Or check if your charger is working properly.
Forgot unlock code voicemail kyocera jax
Go to this link...http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOLScroll down to page #39 to where it says
Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will
automatically erase your old voicemail unlock code as well as any as yet unheard messages. Just in case anyone still has difficulty in finding the instructions.....Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your VoicemailWhen you receive a voicemail message, a notification with a voicemail message icon appears at the top of your screen.• At the voicemail notification, select Call to call your voicemail number and follow the system prompts to retrieve the message.Select Ignore to clear the notification without checking messages. The notification icon remains on top of the screen until you listen to the message• When only the voicemail message icon appears on top of the screen, select Voicemailand follow the system prompts to retrieve the message.
Best of luck!!Susan
I got newer phones and I would hate to h
This phone apparently runs android so you should have a google (gmail) account on it. Check the settings and sync your contacts. Then on your new phone log into your google account and your contacts will magically appear. If you don't have a google account, set one up because this will keep your contacts sync'd where ever you go and what ever smart phone you have.
