20 Most Recent
Mountain Buggy Swift Stroller Questions & Answers
Hi, I have my Mountain
Montain Buggy customer service is generally very good. If not I found tyres at my local Kmart as they are also used on small kids bikes.
Urban elite 2006
My urban elite stroller brake seems to tighten, resulting in the extreme difficulty to flip the break up. I noticed that adjusting the wheel further from the axel helps loosen up the brake. I'm wondering though if there is a better fix to this problem.
How do I tighten the wheel assembly on a 2005-07 Mountain Buggy Urban Jungle Double stroller?
This is a press or pound on type nut usually a one time use! But if you are carefull you can unscrew with a pair of plyers by turning both ways but pulling hard on them! Once you get it off you can put washers on the axle to take up the play. Then before you put the press nut back on make sure you didn't bend up the little pieces of the metal. They should be bairly slanting to the inside of the nut. If they are slanting to the out side bend them in gently. them tap the nut back on!
The plastic joint that attaches
Not really as its properly attached to prevent it coming off by accident.
Contact them don't disclose about it being bounced about tell them they need to honour the warranty unless they can prove you did damaged it and it just didn't break because of a manufacture problem. But the cost it would take and time to determine what actually failed on it would be too much they would just agree to honour warranty
Don't back down on first phone call keep calling until you get some answers..
