20 Most Recent
Recoton Advent Advent RCS110A Remote Control Questions & Answers
Just bought tv made in
Is the remote an OEM replacement for the RCS110a ??
Or is it a all-in-one remote??
Thanks!!
Need code or code search proceedure for Advent RC-S11-0A remote
Most Universals work similar for code search, try this on yours.
[list] [1] Manually turn on the device (eg TV) [2] Press & hold Code button until indicator light stays on (or blinks on some) release Search button. [3] Press & release device button (eg TV). The indicator should blink off. [4] Point Remote at device (eg TV). [5] Press the Power button on/off down until the device turns off. [6] Press the ENTER button or OK button to save the code as soon as the device shuts off. (Suggest you have a finger on it for fast response.)
Hope this works for you.
I bought a 2007 GMC
These types of dvd's are custom installs so the brand and model pf the player would have helped.
On them the sound is sent in 3 ways:
1 - usually there is a cable coming from its audio output connections to the AUX input of the radio. You will have to check the player to see if one was installed; if it has you must make sure the radio is set to use the AUX entry as a source and that the cable connecting them is intact. For testing purposes you should connect a separate amplifier to the player thru these output connectors to see if you get a sound; if you don't then the defect is in the player. Check the audio settings, if they are ok then the defect is hardware and the player will have to be taken to a repair shop.
2 - if the guy that installed it didn't wanted to bother with the hassle of removing the head liner to draw the audio wore then it has most likely just set the connection thru the FM modulator: the player has a modulator that transmits the sound thru the FM radio band; to listen to it all you need to do is to tune it at the frequency of the modulator - usually between 88 and 89.5 MHz.
3 - the headphones - very simple devices. The only thing you can check here are the settings from the player.
I Have Lost My Remote To My Studio Standard RS-912
If you have switched off it by using power button to its remote control, you must have its remote control to switch it back on. Anyway, try pressing the Ch up or Vol up buttons once. In rare cases, this might make it switch back on.
