20 Most Recent
Proview HX303 30 in. HD-Ready LCD Television Questions & Answers
LCD Tv MA-32EF1AC won't turn on
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Why is tv saying no signal?
Connect a known working DVD player by using a new HDMI cable to HDMI INPUT 1 and check for signal.
If you have a DISH or CABLE system box, connect that also with a new HDMI cable to HDMI input 2 or 3 and recheck for signal. Your T V remote will have an input selector to change between the different inputs on your
T V.
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
A brief flash of picture
A brief flash of a picture few sec. and the tv LCD screen panel go black.The tv still have audio sound left?Yes,tv have 1 or 2 the long board that call the LCD inverter boards it is dead.The inverter boards only job are too provided a backlight for the tv LCD screen panel to see a picture.
No picture only sound
I think you might have dry solder joints on the line output stage but if this does not solve the problem then it is a faulty component on the line output stage. If you can do it check for yourself otherwise find a competant technician. Hope this helps.
32inch proview lcd tv has a green square instead
if you are getting color on the screen, chances are that you might have a cable loose. I'm not sure if you are using component cables but sometimes when the blue cable is loose, it will cause a green screen. or if you are trying to watch something above your TV's capabilities, this will happen as well.
