20 Most Recent
Orion STV2763 27" TV Questions & Answers
IO Remote Won't Program to TV
The batteries in the remote may be weak. replace
The transmission window on the remote may be blocked, or the Infra-red diode may be inoperative. No digital signal is leaving the remote. The receiver window on the TV may be blocked, remove obstruction.
Differential test. Does another remote control the tv? If you don't have one remember that the app "Peel Remote" for your smartphone may be used. Does your remote work on other electronic devices? If either is no then that is where your first problem lies.
Screen rolling
hi there, yes there are some adjustmet pods them, but make a mark on it before you adjust so that you can turn it back again in case you lost control of the adjustmet. ty
Help problem with picture
This sounds like theres a capacitor somewhere in the vertical sweep circuit. You can replace the capacitor if you have a soldering iron and some electronic experience on trouble shooting tv sets. It is most likely from what you described the capacitor off the high voltage transformer that supplys the b+ to the vertical output IC. A repair person should be able to give ya a ball park on the cost as Im thinking somewhere from 85 to 135 Bucks depending on if theres only one cap goiung bad or could be a couple or more starting to dry up. So its your ball now .. Do you wanna spend that much to repair the set Do you like the set? is the set over 3 to 5 years old? Its up to you. Good Luck
Channel flipping autom.
you can ask to the cable company. However if you need the channel go to the MENU in TV, AND Auto program for add the 73 channel.If you doubt, download from
www.retrevo.comGod bless you
