20 Most Recent
LG WM2010C Front Load Stacked Washer / Dryer Questions & Answers
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Our LG washer is showing
Hi
Error
code LE indicates that either the motor is not turning or has locked up for
some reason. It can also be due to Hall sensor which monitors direction and
speed of the motor. If the sensor is faulty then also this error appears. Motor
lock can be caused by several things from a loose connector, to a bad motor. To
make sure it's not a locked motor, try turning the drum with your hand. And, if
there is any resistance while turning the drum or the drum doesn't move freely
then the motor is locked and you'll need to get it replaced. If the motor seems
to be fine then you would need to replace the Hall Sensor. To replace the hall
sensor, take the back cover off. Take the big nut off and remove the motor
rotor. Remove the bolts holding the motor windings. Remove the electric plug on
the sensor and unclip it from the motor winding. Hope this
helps...please post back for further assistance.
Daniel
I just bought this washing machine a week
The newer washers are much more gentle on your clothing, but they also take their time to do the job...
Yes, it can be a pain to have it take so long but your clothing will love you for it and will stay nice for you longer...you will also be using less water...
Not much you can do about it as the engineers that know all are the ones that program these things...
heatman101
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
