20 Most Recent
LG F1402FDS6 Front Load Washer Questions & Answers
AE error on lg washing machine
The AE error is indicative that there is a leak somewhere in the washer and it has triggered the flood protection device found at the bottom of the machine. What you should do is find out if there is indeed a leak. Try tilting it forward and find out if water will run out. If you can see water leaking from the water, locate the leak and fix it.
http://www.washingmachineadvisor.com
Singing tune not working
The Beep on/off function can be set by pressing and holding the Option and Rinse button simultaneously.
We turned ours off by accident years ago. Just fixed it after reading this in the manual
Washing machine won't turn on
Is it plugged in? Did you check the fuse? Do you have GFI switches (red and black buttons on the plug) in any room that might be tripped?
LG 1056QD front load washer door will not open.
sensor is not fully trip to open position check the sensor there must be a broken plastic thats prevent the sensor in open position the sensor is located inside the machine behind the door
